Question about HP DeskJet 6540 InkJet Printer
Paper won't feed - HP DeskJet 6540 InkJet Printer
Casio hr100tm won't print, shows E, won't feed paper. It calculates in On mode only.
mi sumadora, de repente se queda en E y no me deja seguir sumando cantidades que solucion tiene esto
Aug 22, 2012 | Casio HR-100TMPlus Calculator
Re; fr3950EP machine, I moved the paper sideways 10mm, light gone out and machine won't start again, display panel just says check paper feed area
Pls, I have risograph FR3950EP
I need the full drum unit, computer interface card, master and inks of different colours. Kindly help me out. I am in Nigeria.email: [email protected]
Nov 26, 2011 | Riso RZ220 Duplicator
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
The machine won't print. It won't feed paper, The
Your machine needs to be serviced.
replace the cartridge with the original one.
it can not print if one cartridge is missing or not original.
Jul 12, 2011 | Canon Office Equipment & Supplies
Green light for paper feed isn't on and paper won't feed
paper start sensor is not functioning properly. clean it or replace it.
Jun 16, 2011 | Canon imageRUNNER 2200
Paper won't feed properly and jams. the paper starts to feed then twists and jams.
There are a couple of possibilities. First is a little piece of paper could be stuck somewhere along the paper path and is causing one of the feed rollers to not grab the paper evenly, which will make the page twist on most of the models in this series, if you pull the paper out and take a flashlight and look up the feed path you will usually see anything in the feed path near/on the rollers at the top.
Another possibility is one of the feed rollers is old and worn out (If machine gets heavy use) and it will cause same issue.
Also light paper stock can sometimes be too thin for the rollers to grab properly and cause it to twist and slide around. This is usually more of an issue with gravity/drop feed printers but can also occur on front feed style too. Usually 20lb stock is good, but if thats doing it, you can try going to a 24lb.
May 06, 2011 | Epson WorkForce 600 All-In-One InkJet...
Print head alignment +won't feed paper
Best solution is to clean the head with it in place,here's
the manual for your printer
Oct 09, 2008 | Epson Stylus Photo R2400 InkJet Printer
HP DeskJet 6540 InkJet Printer Logo
29 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
