Dishwasher works fine until the drying cycle starts (we use the no heat cycle) and then the dishwasher stops working. Found the circuit breaker tripped. This is happening consistently for the last 4 washes.
Are you sure the breaker is big enough to carry the Amps needed to start the drying cycle. You know that due to inductance it takes almost twice as many amps to start a motor as it does to run it.Find out how many Watts it uses and divide it by 120VAC and it will give the maximum amps it will draw. See if the breaker is high enough amp for it. A 25 Amp breaker should be efficient. I hope this helps you and if I can help you in anyway in the future let me know.
SOURCE: Dishwasher power overload
Check heating element in DW and all parts associated with it located on the inside of DW under the spray arm. It could also be a problem with the control panel,Call technician.
SOURCE: dishwasher is "tripping" the breaker & not draining.
I had the same problem with a Hobart AM8 passthru dishwasher. The electrician determined that some of the wires had become exposed and were wet, thus shorting things out and tripping the breaker.
SOURCE: Dishwasher tripping fuse box
Has the door got any heavier, as mine started tripping the electrics when a spring broke and short circuited the connections.
f so you will have to get the spring out, from the underneath is best and replace it if you want the door to work correctly again. On mine the second one went a month later.
SOURCE: The dishwasher starts and initially rinses the
Hi
The issue is with the heating element of your dishwasher, it is withdrawing very large amount of power and thus, the circuit gets overloaded and circuit breaker trips. You'll need to check for any short circuits around the heater element. And, also the resistance of the heater element, it should be around 1.4K ohms to 1.8K ohms.
Please do rate the solution as FixYa and Revert for further assistance.
Thanks
Rylee
SOURCE: Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Good Afternoon friend, thank you for your post!
From my understanding your Electrolux dishwasher is tripping your circuit breaker during the cycles. This could be a wiring issue within your dishwasher and you may need to have a professional technician come out. The technician will have the appropriate tools needed for pinpointing the issue within your dishwasher. Best of luck! -Matt
