Question about HP Photosmart 2610 All-In-One InkJet Printer
HP Photosmart 2610 printer - had been using the print cartridge for quite awhile and all of sudden am getting an error message "Tri-color print cartridge inserted now is not intended for use in this printer". When a new cartridge is inserted, the same error message. I tried cleaning the connections per HP instructions, problem remains.
Posted by zeisbuck on
Anonymous
  • 4 Answers
Have you tried replacing the cartridges all together? That worked for me. I use HP 96 and 97 cartridges.
Posted on Jun 16, 2009
What color and black and white cartridges should I use for a HP Photosmart 1115 printer?
It looks like your Photosmart 1115 printer uses an HP45 black ink cartridge and an HP78 tri-color cartridge. Some HP printers will accept re-manufactured ink carts, while other HP printers will not...just so you know. I've always bought genuine HP ink cartridges on eBay to save $$$.
Jun 23, 2014 | HP Photosmart 2610 All-In-One InkJet...
What to look for when it keeps saying ... Error .... Remove and check color Cartridge?
I suggest you run the 'Tap 10' diagnostic test pattern for your HP PS 2600 series printer model...this will display the electrical health of the ink cartridges and confirm that your printer is operational (I am guessing one of the ink cartridge control lines is open).
http://www.youtube.com/watch?v=RTFOBtdthAc
Good luck
www.inkjet411.com
Mar 06, 2013 | HP Photosmart 2610 All-In-One InkJet...
I have a HP PHOTOSMART 2610 all in one printer and have developed a printing problem. This printer has been working as it should up until just recently. I have been using the Walgreen's photo service...
Because is refill.When refilled a small gap is detached to make the refilling and it no longer recognize as the brand it use.
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 16, 2010 | HP Photosmart 2610 All-In-One InkJet...
HP Deskjet 5550 quit printing red color. Installed new color cartridge HP57. Quit printing red again after 5 pages. Is it a printer problem or cartridge problem?
Have you check your color cartridge if they are properly installed.
Make sure your are not using a refill cartridge.
Replace your tri-color cartridge with original an HP tri-color cartridge.
Aug 26, 2010 | HP DeskJet 5550 InkJet Printer
My HP Photosmart 2610 won't recognise compatible cartridges, help
You can try buffing the contacts gently but this happens quite often with generic cartriges sometimes they just don't work. Contact the vendor and explain the issue, I reckon you'll find that they're fairly used to this problem and will request a return for a refund.
May 31, 2010 | HP Photosmart 2610 All-In-One InkJet...
The color ink cartridge '97' is being rejected by
hi,
this problem may be due to the senser in socket where you are insert the cartridge. so pls clean the socket with cotton using cleanin g liquid eg petrol , spirit or even nail polish remover
Aug 17, 2009 | HP Photosmart 2575 All-In-One InkJet...
Remove and check color cartridge
the problem is the little poorly designed metal thing that is holding up the ink cartridge get's stuck between the cartridge and the printed circuit and it brakes the circuit.must have been some **** drawering on a napkin that came up with that one.wasted a nice unit for that two cent piece of metal.
Jul 23, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
711 people viewed this question
Ekse
efs_perpends
efs_perpends
