Canon PowerShot A1100 IS Digital Camera Logo
A
Anonymous Posted on Mar 11, 2014
A1100is open camera window - Canon PowerShot A1100 IS Digital Camera
3helpful
Canon a1100is camera battery door replacement
Kurt- I have successfully completed a d-i-y battery door replacement on my Canon A1100IS, and I make no claims about being an "expert." My training was watching u-tube videos of guys disassembling digital cameras (other models). Here's how to open the case on the A1100is, which is not really much different than opening the case on most any compact digital camera.
Using a size #0000 phillips screwdriver (Sears sells a set of 6 minis--slotted and phillips--for $10), I removed the nine screws from the side and bottom of the case plus one inside the mini-usb cover and the one inside the battery compartment.
Then, I gently worked the front and rear of the case apart (the top of the case halves have two snap clips that hold them together. Unlike some cameras, the A1100IS does not have any flexible cable straps between its front and rear covers.
With the case halves removed, I then used a tweezers to move the straight end of the hinge spring out of its original place next to the tripod socket. That released spring pressure on the hinge and I could then easily remove the hinge pin with the tweezers.
Then, it's simply a matter of placing the replacement door's hinge/spring combo in the proper location and inserting the hinge pin to hold it there. I purchased a new door from Canon for $8.42 plus shipping). Then, I used the tweezers to position the straight hinge spring end in the slot next to the tripod socket.
The only thing left was to wipe my fingerprints off of the LCD screen and then gently replace the front and rear case halves--snapping the case's top together and then replacing the nine screws.
How do you replace the door on a Canon PowerShot A1100IS?
Take it to a camera or electronics store that does service work. They should be able to order the replacement parts and let you know if it is financially better to repair or replace the camera.
Jul 30, 2011 • Cameras
Powershot a1100is camera card is locked! How do I unlock it?
do u mean sd card then theres this like swich thing just move that to the way that you can
I have a canon A1100IS and the LCD screen will not come on. Any suggestions would be appreciated. Thanks.
Try this.
1. turn it off
2. remove the batteries and memory card
3. reinstall new batteries and the memory card
4. turn it on.
If this doesnt work it will need servecing/repair.
There is no
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ZoomBrowser or any other photo cataloging program.
1helpful
Unable to delete images from memory card of Canon power shot A1100IS camera each time I try it comes up busy and does not respond.
Is there a slide switch on the side of the card? Is it in the locked position? If so, move it.
Dec 23, 2009 • Cameras
2answers
How to down load the pictures from camera with microsft 2003
It's quite simple .Just connect your canon camera to your computer .when it's connected open the folder and simpley copy all jpeg images and past it where every you want
Upload canon a1100is to pc problem
First try uninstalling and reinstalling Zoombrowser. If that doesn't help, it's very hard to troubleshoot software problems online. But why put up with the headaches of bad software in the first place? Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
