Question about Sony Mdr7506 Professional Large Diaphragm Headphone
Nearly constant static
I've been getting static in my headphones for no apparent reason. There's a lot of static when a sound plays on my computer, and then the static continues for several seconds before it makes a popping sound and becomes silent again. I can't seem to find any way to fix this.
Posted by Ethan Seay on
Paolo Torres
    Master:
  • 485 Answers
Your cable or phone jack connection is defective.
Posted on Mar 12, 2014
  • Ethan Seay
    Ethan Seay Mar 15, 2014
    Yep. It definitely was. I've had problems with it in the past too, and I just bought a usb headphone port.
1 Related Answer
SOURCE: Why did my left earbud become silent?
you can make both of the earbuds work. You can open the earbud where the speaker is that you use to hear the musik. Use a soldering iron and a lead. check if the wire inside has removed, fix it back and you will hear sound on both earbuds.
Take care.
Posted on Jun 01, 2010
Audio static
That's pretty normal with built in connectors. For a workaround grab a cheap USB sound card from eBay or somewhere else. It worked for me.
High Quality External USB 2 0 3D Virtual 7 1 Channel Audio Sound Card...
Apr 08, 2017 | Lenovo IdeaPad Yoga 11S Touch - 59370514 -...
I can only hear static through the headphones on my Fostex MR16. The recording sounds fine when I transfer to computer, but I can't hear myself playing.
They make headphone amps that will take a line level and boost it in volume until it can drive headphones. I'd get one of those, and plug it into any available "line out" or "rec out" on the back of your Fostex. Sounds like the D/A converter section that feeds the headphone output has gone bad, and my solution will get you around that.
Nov 27, 2013 | Fostex Mr16hd 16 Track Digital Recorder
Sennheiser headphone static
you might check to make sure that your gain isnt to high many times this can negatively effect your sound quality
Mar 25, 2013 | Sennheiser Audio Players & Recorders
My Canon PowerShot SD300 was recording sound perfectly a few days ago. Now whenever I record a video and play it back there is no sound except for static. I have resetted the settings to factory defaults...
When you play the video back and get no sound are you doing this on your camera or on the computer? I have the same camera, and noticed that when I playback something I've recorded I don't have sound either, mind you I don't have static either. But once I've uploaded the video onto my pc the sound is there.
Jul 29, 2011 | Canon PowerShot SD300 / IXUS 40 Digital...
There is constant static in the left ear when the noise cancelling is turned on. The only way to solve this is to turn the noise cancelling feature off. Is there another solution?
these things are suppost to have a little static noise when on. next time get noise reduction headphones. they are like headphone style ear protection like what construction workers use. but only more stylish and they contain speakers. and no killing batteries for good sound. they are regular headphones but with really good sound isolation
Oct 25, 2010 | JVC HA-NC250 Headphones
Static...
Use third party headphones that are better and it will make the static go away
Jan 21, 2009 | Visual Land V-Touch Digital Media Player
Audio static
Hi: An alignment of the video if and or the audio circuits may be necessary in a repair shop.
How old is this set?
Al
Mar 17, 2008 | Televison & Video
Labtec headphone how to get it to work.
Sometimes you need to "burn in" your headphones. Used headphones usually produce a better sound than new ones. Simply let it play some music continuously. I usually burn in my headphones with some AM/FM static.
After a while, the sound should improve.
Feb 10, 2008 | Labtec 342 Headset
Sony Mdr7506 Professional Large Diaphragm Headphone Logo
413 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
