Cars & Trucks Logo
S
Si Kelly Posted on Mar 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a ford Focus 2006 1600TDC EURO45CAA MJ. The engine oil light goes out after starting then comes back on after a few minuets if the engine is running at 1200 rpm and above it goes out oil level is correct and oil type. Any ideas.
Steven Brandon
Level 3:
Master:
  • Cars & Trucks Master 462 Answers
  • Posted on Mar 12, 2014
Steven Brandon
Level 3:
Master:
Answers
462
Questions
0
Helped
117731
Points
1705
The light works off pressure and it's saying there is not enough pressure when it is in idle but when you bring the rpms up it forces the pump to work faster and causes your pressure to go up thus turning the light off. you probably have an oil pump going bad but a clogged oil filter can do this too. Recommend doing an oil and oil filter change then buy a can of seafoam motor treatment and put all of it into your oil. what it will do is break down any deposits that are built up. It's cheaper to try this than to jump straight to replacing an oil pump. The Seafoam is usually around $10 a can.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
5 Related Answers
c17hydro
Greg Bernett
  • 2993 Answers
  • Posted on Mar 11, 2009
SOURCE: Hi,
What does it sound like?
emissionwiz
Marvin
  • 85242 Answers
  • Posted on May 19, 2009
SOURCE: Oil light comes on
this is an oil pressure light, most likely the sending unit for the gauge is defective,but I do recommened a shop hook up a oil press test gauge and verify u do't really have low oil pressure, then if that tests ok replace the sending unit on the engine.
Anonymous
  • 224 Answers
  • Posted on Jun 29, 2009
SOURCE: 2003 Ford Taurus, 90K, used car, engines shakes, ABS goes on
Are you getting any codes from the Check Engine Light? This sounds like it could have something to do with a sensor. Check your air filter and make sure it's clean. The tach on my 1999 doesn't really work, but it hasn't coincided with other driveability problems. The engine doesn't change in it's RPM's, the tachometer just stops working. Have your charging system checked. The shaking might be coming from bad fuel pump operation, clogged fuel filter, or dirty fuel injectors. Try putting an additive into your gastank to clean the injectors (a bottle of Seafoam is great for this). Try calling your local Autozone and see if they do free trouble code scanning. This might help lead you in a better direction.
Anonymous
  • Posted on Jul 26, 2009
SOURCE: High rev when starting hyundai atos
Check the vacuum hoses, but sounds like the IAC or even the o2 sensors. The computer will pick up on the o2 sensors but not the IAC..Go to your local ADVANCE store and they will check on computer for free :)
Anonymous
  • 1201 Answers
  • Posted on Jul 30, 2009
SOURCE: check engine light has come on
You need a code scanner hooked up to it to find out why the light is on.
If there is an advanced auto or an autozone near you, go there and tell them the engine light is on, and you need a code retrieved. They don't charge for this, where other places do. Tales about a minute.
I was driving (2005 Ford Explorer) & it made a beep,on the dash a pic of an wrench popped up,the dash said "Engine Failure safe mode",within a minuet it died. It also said Low Oil Pressure. Help!
There a problem with the engine. Check engine oil level, before starting vehicle back up. Make sure you are on level ground. Could be a sensor
But, the best thing is find out the Check engine light code, so you or a shop can start diagnosing.
How do I turn off my engine light on my 2002 focus?
Check Engine Light 2003 Ford Focus - YouTube
? 3:17
https://www.youtube.com/watch?v=wOoDJ90aKgg
Mar 26, 2012 - Uploaded by kerobinsonii
Mom called, said her car was blowing up. Her sister told her she needed a tune up and oil change. But all is ...
Reset Engine Service Light on Ford Focus - Seven Trumpets
seventrumpet.com/how-to-reset-engine-service-light-on-ford-focus/
Mar 6, 2015 - To turn off the Engine Service Light on Ford Focus, conform to the following instructions: Turn off the ... The oil change reminder indicator will turn off. This confirms that the ... Resetting the Maintenance oil light on Acura TSX.
Question about Engine Light on Ford Focus... - Straight ...
boards.straightdope.com > ... > Main > General Questions
Have code 0463 fuel levelcircut input high what do I look for
There is no module under the dash on your vehicle .
P0463 - Fuel Level Sensor A Circuit High Description: The powertrain control module (PCM) monitors the fuel level input (FLI) circuit for electrical failure. The test fails when the signal moves above the maximum allowable calibrated parameter for a specified fuel fill percentage in the fuel tank. Possible Causes:
  • Fuel pump (FP) module concern
  • Incorrectly installed fuel gauge
  • Damaged instrument cluster
  • FLI shorted to VPWR
  • CASE GND circuit open
  • Overfilled fuel tank
  • Damaged fuel gauge
Diagnostic Aids: See the diagnostic aids for DTC P0460. Application Key On Engine Off Key On Engine Running Continuous Memory Ranger GO to Pinpoint Test HX . All others Refer to the Workshop Manual Section 413-01, Instrument Cluster for fuel level indicator diagnosis.
You start by taking to Dealer or someother qualified repair shop .
Instrument Cluster Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1202 Fuel Sender Circuit Open Instrument Cluster Go To Pinpoint Test B . B1204 Fuel Sender Circuit Short to Ground Instrument Cluster Go To Pinpoint Test B .
The oil light comes on when i'm stopped and when i drive the oil light goes off however i opened the hood and i've notice on the side of the engine block i see oil moisture around the block and oil that...
The first thing to do is check the oil level and top it up and then check it quite often until you get the leak fixed.
To find the source of the leak, wipe the side of the engine down with a rag to clean off the excess oil. Start it and let it idle while you watch for oil to start coming out. Focus on the area where the oil stops. Occasinal reving the engine may help. I'd be looking at valve cover gaskets as the most likely cause., They are an easy back yard fix. Hope this helps.
1helpful
Ford focus 1.6 tdci 05 plate-intermitting oil light
I believe your oil pump is not working, Please do not start the car anymore or your engine will suffer severe engine damage, have it towed to your mechanic.
2helpful
My ford focus 1.6 petrol engine is leaking oil from the back of the engine. How can it be fixed?
hi i have a 2001 1.6 zetec ford focus. the engine managment light is on and my car has bee leaking oil into the airbox on the floor and onto the gearbox coming from the rocker cover breather hose ( i have changed the camshaft breather hose and valve ) any suggestions ?
1helpful
My 2005 ford focus engine light just came on. Nothing seems to be wrong with it. I'm at a loss..???
You may want to check your belts, make sure they are all turning as the engine is running.
check your oil to be sure it is not overfull or underfull.
Make sure it's not overheating.
If you have an autozone nearby and have verified the oil and temp are fine, they usually will hook up a code scanner to identify any problems with sensors and such.
You may also want to just inspect the wire that goes to the oil pressure sending unit and/or oil pressure switch, either loose or disconnected can cause the engine light to come on.
good luck
2helpful
FORD FOCUS OIL LIGHT STAYING ON
i have exactly the same problem, same model and year, car runs perfect but oil light comes on after 5 mins or so. its got me stumped!
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
