Sharp CD-BA200 CD Shelf System Logo
r
rose lofton Posted on Mar 12, 2014
Cd-ba200 cd is not reading
We put a cd in the tray and it does read it. it will play the first two tracks on the cd then skip
5 Related Answers
Anonymous
  • 82 Answers
  • Posted on Apr 11, 2008
SOURCE: i have a sharp system and whenever i put a audio cd created using nero it dosent work, the sharp system reads the amount of tracks on the cd and the total time of all the tracks, but dosent play the t
Try using the cd created on another stereo system to confirm that it works. Also try using different type blank disc when burning.
Anonymous
  • 82 Answers
  • Posted on Mar 27, 2008
SOURCE: mini sharp stereo
Try pressing the play button on the remote. If it works correctly, the play button on the unit may be defective.
A
Anonymous
  • Posted on Nov 09, 2008
SOURCE: Sharp CD PC3500 CD Shelf System CD track jumps and doesnot complete song
it seems tht u have a faulty lazer which is common in these types of stereos try smeering **** over it or eating it if it dnt work u will still feel much beter about yurself
caroldon
  • 17130 Answers
  • Posted on Mar 15, 2012
SOURCE: my sharp cd-ba200 will barley play cds
Put the player On for few hours or overnight. Now remove the panel and get access to the optical head unit, use a clean ear bud to polish the optical head. If not the optical head is weak and must be replaced.
Anonymous
  • 6771 Answers
  • Posted on Mar 17, 2012
SOURCE: sharp cd xp 120 CD play button does not work.
The pad switch"hidden under the button" is more than likely the issue.
Testimonial: "I figured out it goes right to a circuit board that has the buttons on it, the board itself needs to be replaced. Now just have to find one."
1helpful
2answers
Hi ..I have Pionner PD-M701 CD Chanager .the player works so fine and recognize all cds in the trays but the issue is in the reading .
hi Sam.
you could try this.
Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lens cleaner.
Why does a CD player skip? They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.
.or try this link for more info.
cd player skips Google Search
The cd player goes into a "skipping" "playing really fast" mode occasionally. Esp. 3rd track, 1st cd. Always has.
It's having trouble reading the CDs. The thing that reads it could be dirty. But try a different cd. The CD player is getting old and if there is even a small scratch it will be hard to read it. A new CD player would be the way to go
My sharp cd-ba200 will barley play cds
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
2answers
My does my cdj keep skipping on track 1 and 2
Try a head cleaner first and if that doesnt work then look around for a new cd player or use the computer as if its what i think it is then its not reading correctly and it not really repairable ,Well financialy viable as i think the memory reading of the circuitry is questionable.
The CD will not advance to the next track. One track is played and then it stops and waits until I program it to play the next track.
try when u turn it on. check all your bottons 2 make sure they r not stuck and than put a cd n and check 2 c if it will read the hole disc. or push play with a cd in there an try 2 skip songs 2 play
1helpful
4answers
My xbox 360 doesn't play my games
check if you CD is break in the center. If it break, go in a EBGAME and told them your problem.
Player 2 skips and plays a different track
May need manual cleaning or Cd Mechanical assembly may need to be replaced
2answers
Static and skipping
You might need to have it professionally cleaned / diagnosed. The problem might not be a dirty reader, but a misaligned tray. Many trays, over time, become misaligned. Some more than others. Depends on your use and abuse of the unit. The issues generally happen towards the end of the tracks.
- OPTiC
DJ Pro Lab
1200s.com
CDs wont play
archo69..big chance your laser is on its way out..it also can be the bottom lense is dirty to ,but this requires your stereo to be removed .dismantled and cleaned manually
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
