I got new remotes. the remote will start the vehicle but when I lock/unlock the vehicle responds but doesn't physically lock the vehicle
SOURCE: driver's door won't unlock with remote
This may be a problem with wiring. I will need to know what the make and model is of the car. Also keyless entry system stock OEM or was that an option you have added? Lastly, did you install this system or was this installed by a cetified DEI corperation?
Thank you,
Luis
SOURCE: remote keypad
Like I posted for another question.....
Try removing the 15 amp fuse on the red wire to the brain of the alarm. Wait a few minutes and reinstall. I have the Clifford version of this alarm and have had to do it a couple times. Also try the one way remote and see if it works. If the one way works and the two way works but gives an error this show fix it (for awhile). I think DEI is having a problem and don't want to do anything about it.
SOURCE: My viper 5701 2way remote works, but gives buzz for all functions
hi did you get this unit from ebay? i am going through the same experience right now and there is a problem with the early units that were manufactured. It will need to be replaced. I am currently trying to get a refund.
SOURCE: Remote car starter worked last week but this week
It probably needs to be re-programed Programming the Viper Remote Starter 5101 Unlock the doors before starting Push and hold f button for 8-10 seconds until amber light is on solid Push Remote start button for about 4 seconds till amber light flashes 3 times Put key in IGN to the on position but don
I have a viper model 5101 and this is how you program it Hope it helps !
