Question about Yamaha Electrical Supplies
Generator running full throttle - Yamaha Electrical Supplies
Posted by Elizabeth Davies on
tebrown507
    Sergeant:
  • 415 Answers
Most generators, when started, will run at full throttle. This will allow them to pick up load quickly.
Posted on Mar 12, 2014
Honda generator eu3000is Not getting power to carb in order to meter fuel
After reading about Honda's Eco Throttle system available on inverter generators it seems it is not a fuel metering system but a computer controlled speed regulator or basically an electronic throttle.
Because the engine of an inverter generator doesn't need to run at a constant high speed to produce the correct 50 or 60 Hz output this generator can run at slower speeds when the load is light. The electronic throttle is the means to make it happen - operated by the computer.
The throttle is probably operated by a stepper motor and the power supplied to it likely to be in digital form. I suggest you try and gain a more full account of how the system works before you delve deeper.
Nov 09, 2017 | Honda Electrical Supplies
5500 watt generator will not run my 2hp air compressor
5500 watt generator will meet the 1491.4 watt requirement of the 2 hp compressor motor
given that 5500 watts generator is rated continuously at around 4500 watts and will handle spikes to the 5500 watts when electrical components start there should be plenty left
consider the possibility or a motor below full capacity, carby problem ( jets blocked , water, blocked air filter not getting full throttle from the governor lever, worn rings, type of fuel in use --E mix)
Nov 18, 2015 | Electrical Supplies
How to fix my generator
Generators are designed to run at full throttle, for optimal power output.
Dec 26, 2014 | Electrical Supplies
My Honda EB3500X Shuts off when auto throttle is switched on making me run full throttle at all times. Cause? Solution?
if your engine shutting down, then your auto throttle is working.
when you hit the switch watch the throttle arm move on the carburetor to the idle position,if so you may have to clean the carburetor jet and fuel nozzle ports.possibly this occurs when unit has been stored for quite some time.once jets are cleaned it should maintain idle.
May 31, 2014 | Honda Eb 3500 Generator
Why it want make electricty are load up?
Must be up to full running RPM to generate the right operating voltage. If it is running at full throttle and there is no power out, then the generator head needs to be repaired.
Feb 06, 2014 | Coleman Electrical Supplies
Coleman Powermate full throttle
There may be a choke handle that should reduce the engine RPM. Otherwise contact the Coleman technical support department.
Dec 22, 2013 | Coleman Powermate Powermate 5000W...
Slow throttle reponse to load
Your welder is too much for the generator you are using. Usually you need a fairly big generator for welding so it doesn't overload so easily.
Nov 18, 2013 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
Throttle on generator question
The idle control switch allows the generator to go into idle when there is no demand form the appliances connected. This saves gas and increases the life of the generator. Damage can occur for some appliances like a refrigerator/freezer because the voltage and frequency are not prepared for the load resulting in a low voltage bad startup that will damage the appliance. Suggest that you leave the idle control switch off while any motor/electronic devices are connected.
The throttle control is likely a choke function for starting. These generators are designed for only one running speed to produce the necessary 60 cycles per second and voltage.
The following link is to a Canadian web site that later in the detail report describes the concern of idle control. In addition it provides good insight to the operation and use of portable generators
Hope this helps?
Understanding Portable Generators
The user manual see pages:
http://www.mikestools.com/download/Porter-Cable-Manuals/Porter-Cable-CTE300.pdf
May 06, 2017 | Porter Cable Portable Generator BSV750
Running at idle speed
1) Check the "Economy Throttle" setting (or some similar verbage). Inverter types dont have to run full speed to produce full voltage.
2) Apply a load. These magically accellerate and decellerate according to load conditions.
Hope this helps,
Dolf-
Oct 13, 2009 | Yamaha 2500 Watt Industrial Inverter...
Fuse blows repeatedly
The auto speed control is failed. Keep it manual and see how it does...It will run at full throttle even when no load is running. Then fix the throttle control when able.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 09, 2009 | Generac Guardian Ultra Source 15,000 Watt...
Electrical Supplies Logo
155 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Robert Wooley
Robert Wooley
Dan Horsefield
Dan Horsefield
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
