Question about Lenovo G550-29583AU Notebook
My lenova g550 hard disc indicator light won't turn opn. the screen is black
The battery is charged- the power is on - the hard disc indicator light flashes on initially and then goes off- the screen stays black
Posted by lexikate on
Ed J W L
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 32 Answers
Have you made any modifications to the computer lately? (Taken it apart ect?) I had a similar issue with mine. There was a short in the keyboard. I ordered and installed a new keyboard and it has booted up fine ever since.
Try something as simple as checking the keyboard connection, this will require taking the laptop apart though.
Posted on Apr 24, 2014
5 Related Answers
SOURCE: Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Posted on Jun 24, 2010
Jemalyn Labaguis
  • 794 Answers
SOURCE: My Lenovo, G550 turns on
Hi eseitz26,
For your G550 issue that no display will show on your screen after turning it on although all the lights are showing there are different reasons why you're getting this issue. The two most common issues are:
(1) The system just needed to be refreshed and reset the BIOS. Don't worry because resetting BIOS is just easy and you can do this on your own. Simply power drain your machine.
Here's how: Shut down your PC >> Remove the battery and unplug AC adapter >> Without any power source press and hold the power button for 15-20 seconds (nothing will happen yet) >> Put back the battery and the charger >> Then, turn on your PC.
(2) The LCD cable from your screen going to the motherboard is loosed, that needed to be repaired or defective, and it needs replacement. For this one, you may contact Lenovo to give you options about the repair.
Well, in some rare cases screen might be also defective and needs replacement. You may also take a look on that possibility.
Hope this helps.
Thank you for using Fixya.
Posted on Mar 01, 2011
134naveenkum
SOURCE: Hello Sir, How do i reset
in my laptop g550 bios password is set i am change the password
Posted on Apr 11, 2011
SOURCE: My lenovo G550 appears not
Hi m529,
I see you are having issues with you G550 charging.
You mentioned that the light on the charger is lit up but then it suddenly switches Off, and you also mentioned that the charge still has a light but the power is somewhat low despite of a fully lit up charger Light.
Have you tried draining the power from the system?
  • Remove the battery and the Charger or AC Adapter as well call it from the G550 then press and hold down the power button for 10-15 seconds to drain power from the system motherboard.
  • Once drained connect the AC adapter but do not connect the battery yet, then turn the Laptop ON to see if the system will power ON using the AC adapter/Charger if it powers up then there is no problem with the AC adapter/charger.
  • After testing the AC adapter if it is working power down the Laptop doing a normal shut down.
  • Once shut down or turned Off insert the Battery back in the Laptop then turn the Laptop ON using the battery only without the AC adapter/charger see if the system will turn ON using the Battery only.
  • If the Laptop powers On using the battery alone with out the AC adapter then the battery is most likely working as well on the issue.
  • Now power down the Laptop then connect the AC adapter to the Laptop with the Battery in the Laptop as well then turn the system ON again see if the problem will Occur again having the battery and the AC adapter/charger if the Problem happens with both Battery and AC adapter on the Laptop then the problem is the Motherboard, most probably the motherboard is having issues relaying power from the AC adapter to the battery and may be sent to the Depot for repairs.
I suggest that you call Lenovo for further information about your system, if you still have warranty and is still in the one year period then your system will be covered for any repairs needed - you can call @ 1 877 453 6686 for troubleshooting, you will be asked for a serial number Located underneath the Laptop on a small white sticker that states s/n meaning serial number.
I hope that this Helps.
Have a nice day,
mvincentc
Posted on Jun 21, 2011
StuartB
Stuart
  • 807 Answers
SOURCE: lenovo g550 orange flash 3 times
3 orange flashes means flat battery. If you have a faulty charger or charger socket on the laptop then the battery wont charge or power up with just the charger connected.
Look here:Lenovo
Posted on Feb 01, 2012
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
Lg lucid screen went black
Remove your battery, and leave it out for a minute or so, put it all back together, and charge... it may look lie it isn't, but since this phone seems not to have an LED the navigation buttons are your only indicators of trouble(pure speculation).
Your battery is probably depleted. i found out the hard way that a Droid X won't charge it properly... hope this helps
Jun 24, 2012 | LG Lucid 4G MobiPhone - Black Verizon...
Lenovo g550 turns off when power supply is disconnected ,battery shows fully charged
Replace the battery, it's faulty.
Batteries only have a useful life, then they have to be replaced. Sounds like yours is doing like the ink cartridges, where they register as being full of ink when actually there is no ink in the cartridge.
May 18, 2012 | Lenovo G550 Notebook
I have a Lenova laptop and a intel MB I am having a problem. Trying to login but the supervisor password won't let me in no matter what i try Lenova G550 2958
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased. Hope this helps
Aug 13, 2011 | Intel Motherboard
Lenova g550 no power problem
Try to remove the power cables and battery to it. Press and hold power button for 8 secs. Reinsert the battery and power cables then turn on. If it is no power, it might be a power supply or the motherboard issue. Kindly call lenovo to schedule for a repair of such parts...
May 03, 2011 | Computers & Internet
When i switch on my laptop, i see that ll the 4 LEDs are glowing initially, but the LED that seems to have the DISC image next to it goes low after a while and nothing seems to happen after that. At no...
In this cae, it might be, but to make sure, pls turn off laptop. Remove cables and battery then press and hold power button for 8 secs. Reinsert cables and battery then turn on pc. If same happens, that is a hard disc failure. Consult lenovo for possible repair...
Aug 08, 2010 | Lenovo G550-29583AU Notebook
Lenovo G550-29583AU Notebook Logo
82 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
