Question about Necchi 4575 Mechanical Sewing Machine
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked
Posted on May 06, 2014
Feb 08, 2017 | Sewing Machines
Oct 01, 2014 | Kenmore Sewing Machines
Sep 02, 2014 | Sewing Machines
Dec 04, 2017 | Janome Sewing Machines
Feb 20, 2011 | Kenmore Sewing Machines
Dec 08, 2010 | Necchi 6015 Mechanical Sewing Machine
Nov 26, 2010 | Singer 2259 Sewing Machine
Sep 06, 2010 | Sewing Machines
Feb 01, 2009 | Sewing Machines
Feb 06, 2008 | Necchi 4575 Mechanical Sewing Machine
119 people viewed this question
