My scooter is completely dead and won't switch on. The battery is charged, I pressed the reset button and put in a new fuse for the control panel as the old one had blown. The scooter switched on with the new fuse, but then went dead again.
My chair, a Dalton HD, keeps blowing fuses. Before it blows, the batteries can be fully charged but then show nearly dead in just a few moments, even when sitting still. It yo-yos indicator lights up and down, sometimes for days, then suddenly blows fuse. The battery cable is also very warm. Any ideas?
Hi, so has the fuse blown again ???
Regards
Rob
www.gewizrepairs.co.uk
SOURCE: scooter will not charge
sounds like the gell batterys you can try a battery conditioner it may charge them enough for your charger to work again .if the batterys are not charged or used for a wile the batterys will not let the charger work they should be charged almost all the time
SOURCE: Scooter has full charge but still won't go.
It probably means that the connections or wiring from your battery are loose or broken. When you add the extra current required to run the motors, the voltage is being lost. Monitor the battery voltage with a meter while trying to drive the scooter will prove this.
SOURCE: scooter is dead
Are you sure your charger is working? Is the free-wheel lever engaged? Also the charger has an inhibit line, it will not run when the charger is plugged in.
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
SOURCE: triton pl3-01 scooter wil not take charge
I just bought a Triton Products Ltd. electric three wheel scooter that has gone dead.We followed all the manual instructions but the electricity will not go from the battery to the controls Also I can't reach Triton Products Ltd. on any phone numbers they gave us.I'm 77 and need my scooter.
