Question about SanDisk Sansa e250 MP3 Player
Flashing screen everytime i turn on my sansa its just comes up with sansadisk then slowly fades out to white and does this all over again until i put it on hold to turn it off .....
Posted by jessssssssse on
  • jessssssssse Oct 30, 2007
    it didn't help at all nothing came up on my computer screen
  • Anonymous Nov 01, 2007
    Yeah, I have a problem that was similair to that description, I thought it might be a virus that was downloaded on accident, but since I'm not the only one, I don't know what it could be.
HannahIm
I am having the same problem. I tried this solution but the program just said "no valid device appears to be connected." My Sansa is definitely connected physcially to the USB. What's next?
Posted on Oct 31, 2007
  • HannahIm Oct 31, 2007
    Wow, I tried it several times and it did work now! Thanks so much!
Timothy D
  • 626 Answers
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Oct 30, 2007
  • Timothy D
    Timothy D Oct 30, 2007
    You may need to try it a couple times.
    It always works....
My sansa turns on but dissapears and comes back again
does this device gets detected by the computer? if yes then do a formware upgrade. this is due to firmware problem.
Jul 27, 2009 | SanDisk Sansa e250 MP3 Player
Sansadisk mp3 is frozen
just wait until batteries run out.
May 07, 2008 | SanDisk Sansa Clip MP3 Player
Screen fades out whenever i choose a song
Software corrupt. Try finding out how to install it again or update firmware. If you cant, get another brand. THey like cheap, stop trying to ressurect the dead
Apr 11, 2008 | SanDisk Sansa e260 MP3 Player
Sansa wont work
Download the Sansa firmware upgrader and install it first. Then, hold in the volume + button on your Sansa player and connect the Sansa to your computer (while it is in the OFF position). The computer will recognize the player after you continue holding the volume + button for 5-50 seconds. Restart your computer. You will lose all files stored on the Sansa, but it will work again.
Mar 29, 2008 | SanDisk Sansa E280 MP3 Player
White Screen.
unintall the device from the computer and try to reinstall it again..if that doesnt help you you will have to get a new new device from sandisk...
Jan 03, 2008 | SanDisk Sansa e260 MP3 Player
My sansa wont boot up
The best results that I have had were to hold the power button for about 15 seconds. ( if you only hold it for 3 seconds it goes into sleep mode). This shuts the device off. Then restart it.
Dec 12, 2007 | SanDisk Sansa e250 MP3 Player
Slowy fades to white
This will take care of it.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
Best of Luck.
Nov 17, 2007 | SanDisk Sansa e250 MP3 Player
Evry time i turn on it comes up with sandisk then...slowly fades out white and does this again...untill i reset
Mine does the same thing. Every time I turn it slowly fades it to white..and than it does it again. I don't know how this happened. I was listening to it right before this happened. I Need help.
Wont work
Hopefully you find an answer, because i am having the exact same problem, please post your answer
Dec 27, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
