I have a small alarm clock with model # alck-487 and three buttons M, S, D. i can't find the right combo of push and/ or hold to change the time. can you assist?
Posted by geoff johnson on
Andre Marmet
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
ALCK-487 reset time:
Press M three times, you will see the seconds flashing.
Then press S once to adjust minutes, press D,
press S a second time to adjust hours, press D,
press S a third time to adjust date of month, press D,
press S a fourth time to adjust month, press D,
press S a fifth time to adjust day of week, press D,
Then press M to end settings.
Posted on Mar 14, 2016
5 Related Answers
Anonymous
SOURCE: Accuwave DS Clock
The radio may not be able to get a strong enough or clear enough signal to process (night is best away from TV, computers and radios).  To regain "control" of the clock, take the battery out, wait 30 seconds and then reinstall it.  This will reset the clock.  You can then manually set the clock.
Press SET for a few seconds until the hour starts flashing in the display.  Then press the ADJUST button to set the hour.  Press SET to move to the different functions (Hour -> Minutes -> Seconds-> Month -> Date -> Year) each time using the ADJUST button to correct the setting.  Finally press MODE to exit the setting mode.
If the time zone is incorrect for your area (default is PST), press MODE to enter the Alarm Time Mode; then press SET to flip through the time zones; then press MODE again to exit.
The little "reset" is for use if the LCD display doesn't come on when the battery is changed. It doesn't affect any of the clock settings per se.
Posted on Nov 04, 2008
Anonymous
  • 42 Answers
SOURCE: How to change the time on clock radio
I'm not 100% sure if this is right or not, but i used to have one similar and the way to reset it was:
  1. Press the SET button.
  2. After the time blinks, press the REV or FWD button to adjust the time. (Press and hold the REV or FWD button to fast reverse or fast forward time.)
  3. To save settings press the SET button.
  4. Once you have the clock set and have press the SET button, the time should be done blinking.
Give this a try and hopefully it works, good luck
Posted on Nov 10, 2008
Anonymous
  • 814 Answers
SOURCE: Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 15, 2009
Anonymous
SOURCE: I can't set the time, the alarm time, or do anything of that sort
AHAH! I had this problem also, so i tried google and it led me here. Luckily, I kept trying and figured it out so I will share my knowledge with you although you may have found it out already...
First, make sure the radio and ipod are off and it's in clock display mode.
Then, click and hold "alm set" while clicking the left "timer set" arrow to set the hour of your alarm and the right "timer set" arrow to set minutes for your alarm.
Then click "alm on/off" to turn it on and off.
Posted on Oct 19, 2009
Anonymous
  • 8197 Answers
SOURCE: alarm clock GE model no. 7-4894A but no manual
You can down load the manual on link below for free.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000045591.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Apr 29, 2010
Set time on a alck 487 clock
The manual has the complete process how to set time.
1helpful
9answers
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 • Watches
2answers
What size button battery do I need for my ALCK-487 mini clock?
There is a picture of the battery L1131 TS Button cell.
3helpful
ALCK 487 mini clock. How do I stop hourly bleep?
I have the ALCK 487 (mini clock I can stick to anything, since it has a backing strip) and I can't remove the function that makes it bleep every hour on the hour
Answer: Press and hold "S". If you see the seven days of the week, press "M" to erase them. it will stop beeping every hour
Sep 30, 2013 • Home
I have a clock that will not get correct time. I have no way yo set it . Model #44100 Equity.
All Equity Insta-Set clocks automatically set the correct time and date when you turn on the power. Occasionally, the automatic time-setting feature malfunctions and you must reset the time yourself. Manually changing the time to the correct time on an Equity Insta-Set clock requires the push of only a few buttons to get the clock back on track:
1. Press and hold the "Alarm Set" button for five to seven seconds, the year will begin to blink when the clock is ready for adjustment.
2. Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock
3. Set the month, day, hour and minute. Press the "Alarm Set" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
4. Press the "Alarm Set" button after setting the date and time to store the information into your clock's memory.
Best regards,
gylacz
25helpful
Surface Watch Model 31819 How do you turn the alarm off?
I have a Surface Watch. Not sure if it's the same model number, but the button set up is the same. Here's what I did:
Hold down the bottom right button. While you're holding it down, press the top right button. My bottom right button doesn't seem to always work, so it made it rather difficult to figure out what has going on.
Dec 03, 2009 • Watches
13helpful
3answers
SHARPER IMAGE -- M1600 / M1601 Swivel world time clock .
Push the mode button until the top window says 'Alarm', push the up or down button to shut off the alarm, push the Set button to set it.
Mar 05, 2009 • Watches
7helpful
3answers
Emerson Smartset alarm clock
Hi - You can download the manual from the link underlined in blue below:
CKS3528
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Open Questions:
 Grubhead
Grubhead
Marvin
Marvin
