Question about JVC Cybercam GR-DX75 Mini DV Digital Camcorder
GRD53AG i CANNOT GET AN IMAGE ON MY SCREEN DO i HAVE TO HAVE AMULTIMEDIA CARD INSERTED OR SHOULD IT WORK WITH CASSETE.iT SAYS LENS CAP BUT LENS CAP NOT ON
Posted by BOB WARD on
Anonymous
Pl. let me know whome to contact for the same problem where we will get the service for this as I'm residing @ Bangalore -INDIA.
Thanks & Regards,
Shashi.
Posted on Feb 12, 2008
Anonymous
    Champion:
  • 217 Answers
Defective ccd imager!! company will replace this ccd imager free of charge. Year 2002 up to 2005 released unit has a factory defect ccd imager. the company recalled those units and replaced with a stronger version of ccd imager ( they are still doing it). check it out.
Posted on Oct 29, 2007
It won't allow uploading Lens keeps trying to open behind close cap
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Jul 25, 2012 | Nikon COOLPIX P90 Digital Camera
No image was shown on screen while i still can take photo.
According to ehow:
Turn off your Canon 1000D and remove the memory card, lens, battery and time/date secondary battery. The secondary battery is a small, round battery about the size of a dime found in the same compartment as the main battery. It is located in a vertical slot. Slide out the secondary battery by pressing your finger on the battery and pulling it toward you.
  • Place the body cap on your camera to keep dust out. Attach the front and back lens caps on your lens to prevent scratches and other damage.
  • Let the camera sit for 20 minutes. This will clear the camera's memory.
  • Place the date/time secondary battery and a fully charged primary battery in the camera and turn it on.
  • Press the shutter release button (the button you push to take a picture). If you are still receiving an Error 99, the problem is most likely caused by the camera body itself. The camera body must be serviced by a professional camera technician.
  • Turn off the camera and insert the memory card. Turn the camera back on and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the memory card. Turn off your camera and insert a different memory card. Turn the camera back on and press the shutter release again.
  • Turn off the camera and reattach the lens. Turn on the camera and press the shutter release button. If you receive an Error 99, turn the camera off and remove the lens.
  • Turn the camera so that it is face down, and gently clean the lens contacts on the camera body with a number 2 pencil eraser or soft cloth. The lens contacts are the eight small, gold pieces on the bottom of the lens mount. Be careful not to let any of the eraser scraps fall into the camera body.
  • Turn the lens so that the side that attaches to the camera is upside down. Use the eraser or soft cloth to clean the lens contacts on the lens, being careful not to let any eraser scraps fall into the lens.
  • Reattach the lens to the camera. Turn on the camera and press the shutter release button. If you are receiving an Error 99, the error is most likely caused by the lens. Take the lens to a professional camera technician for repair.
  • May 11, 2011 | Panasonic Lumix DMC-FS4 Digital Camera
    HOW DO I WORK A DIGITAL CAMERA?
    STEP-BY-STEP INSTRUCTIONS FOR OPERATING YOUR FIRST DIGITAL CAMERA
    1. READ YOUR CAMERA MANUAL before taking any photographs.
    2. Check your batteries. Make sure to either recharge or replace them if you haven't used your camera as yet or for an extended period.
    3. Insert your storage media card in the appropriate slot. If you forget to insert your media card, you'll get a "No Card" message.
    4. Remove the lens cap.
    5. Turn the camera on by either an on-off switch or a sliding lens cover.
    6. Turn off the LCD. (See your camera manual for instructions)
    7. Make sure your camera is set for automatic mode. Set the image quality to the size image desired-HQ (high quality) or less (to take more pictures on the same card).
    8. Bring the camera up to your eye and look through the viewfinder. Positioning the target mark in the center of the viewfinder on your subject will assure that it will be in focus.
    9. Push the zoom lever toward W (wide angle) to shoot wide-angle shots or push it toward the T (telephoto) to zoom in.
    10. Press the shutter button half way down gently and confirm that the green light next to the viewfinder is illuminated.
    11. Press the shutter button all the way down. You'll hear a beep when you take a picture. Wait until the green light stops flashing before taking another one. Remember, digital cameras have a slight delay that traditional cameras don't since it takes a second to save the image to your camera's storage media card.
    12. Turn off the camera. Your new photograph should appear on your camera's LCD screen.
    TIPS:
    1. Use the viewfinder to compose your photograph, not the LCD screen, which will severely drain your battery power. Use your LCD screen only when shooting close-up photographs.
    2. Hold your camera steady. Sometimes, the least amount of movement will cause your photo to be slightly blurred. Purchase a very small tripod so that you can provide extra stability for your camera. Also, if there isn't enough light (indoors or outdoors), make sure to use your camera's flash.
    3. Experiment with your camera's features and take notes so that you can learn what works for you. Do this before you plan to use it for an important family event or trip.
    Dec 15, 2010 | Cameras
    JVC-GRD31U Says ''Lens Cap'' No image.
    It is known problem of bad ccd imager in JVC GR-D31U camcorder that gives Lens Cap error and JVC will replace ccd imager free of cost.
    Click JVC CCD Imager Support for details.
    Thanks.
    Aug 25, 2009 | Video Cameras
    Lens Cap problem
    It is known problem of bad ccd imager in JVC GR-D30U camcorder.
    JVC will repair it free of cost. Please click JVC CCD Imager Support for details.
    Thanks.
    Aug 04, 2009 | JVC GR-D30U Camcorder
    Lens Cap Error
    You have a defective CCD imager - the part of the lens that receives the image. Will need to be replaced.
    Aug 03, 2009 | JVC GR D650US camcorder
    My Sony DCR DVD 108 has no image at all with or with out disc says lens cap may be closed but it isnt flashing E:61:11 top right hand side of touch screen plays previously recorded dvd fine but thats it.
    You may have lost your image sensor.
    1. Take lens cap off.
    2. Look in lens make sure there is nothing on or blocking lens.
    3. Find bright room & see if image comes up.
    4. Make sure your in video record mode.
    5. If you have eyepiece lens look to make sure it is off. {Most cams will not let you use both at same time.}
    6. Still no image try recording on blank disk then play back see if image is recording.
    If that does not work MSG back.
    Mar 07, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
    New casset insertion not displaying any image on the screen
    JUST BUY A CLEANING CASSETTE AND PLAY TWO OR THREE TIMES AND PLAY YOUR RECORDED CASSTTE.IT WILL BE VERY CLEAR.
    REGARDS
    SANKAR
    Oct 24, 2007 | JVC GR-D370 Mini DV Digital Camcorder
    DHR- 1000
    Recently repaired one of these with what appeared to be a power supply problem; found several defective capacitors on the drive board. The symptoms were similar to what you are seeing.
    Aug 20, 2007 | Sony DHR-1000 DVHS VCR
    JVC Cybercam GR-DX75 Mini DV Digital Camcorder Logo
    90 people viewed this question
    Top JVC Video Cameras Experts
    Ekse
    Larry Stiles
    Larry Stiles
    Al Rush
    Are you a JVC Video Camera Expert? Answer questions, earn points and help others
