Unplug the power cord, remove the battery pack, and leave it out for a minute or so. Reinsert the battery and turn the computer on. Does it boot normally now?
You may try starting a clean cycle again. This sometimes will run the lock motor to unlock the latch after it sets the lock. Cancel the clean after a few minutes. I hope this will help.
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Hi there.. Regarding with your issue, one of the possible reasons why is that the printer is saying that it's because there might be a big chance that there is something wrong with the scanner bulb of your printer that can lead into a hardware failure.. now here's the document that you will need to follow to resolved the issue. open this link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00587971&cc=us&lc=en&dlc=en&product=421991&tmp_track_link=ot_search#N82
now after doing all the steps on the website and if it didn't help, then do a semi full reset by unplugging the power cord from the back and then press the # and the number 6 at the same time while the power is off..after a few seconds reconnect the power cord from the back of the printer while still holding those buttons up until you see something on the screen of the printer saying "nvm reset" something like that.. but still after doing a reset and it didn't fix the problemthen the printer is having a hardware failure or in other words it become faulty. if you have any questions, dont hesitate to reply on this message.. Goodluck!!!
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it.
Press and hold the “*” key. Press the “#” key and release both keys. Display should say “Enter Special Key Combo” Press and release in sequence the "1”, “2” and “3” buttons. Display should say “Support” and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says “System Configuration Menu”. Press and release the “OK” button. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”, Press and release the “OK” button. Display should say “Hardware failure status: Clear. Press OK to clear”. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
