Panasonic KX-T7431 Corded Phone Logo
D
Damian OBrien Posted on Mar 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CO Not Assigned - unable to select and outside line
I entered a new number into a spare one-touch station on my phone but now I can't use any of the one-touch speed dials and when I select 9 for an outside line I get the engaged signal and message "CO Not Assigned". Any help would be gratefully received. Damian
www.wanetelecoms.com
Level 2:
Habit-Forming:
New Friend:
  • Expert 81 Answers
  • Posted on Mar 12, 2014
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
81
Questions
Helped
29857
Points
112
Did you not assign a speed dial CO buttton to an extension
5 Related Answers
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Oct 08, 2008
SOURCE: KX-T7731 messed up the co button
Remember that PROG 13 you pressed? First, press PROG and touch CO-1's button and make sure it still say CO-1. If not, dial 01 STORE and it will become CO-1 again.
Now, pick up the handset and hang it up so you clear the phone and press PROG 13 1 STORE PROG
Easy when you have the manual :-)
Carl
Anonymous
  • 201 Answers
  • Posted on Aug 13, 2007
SOURCE: Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
Anonymous
  • 14 Answers
  • Posted on Jun 25, 2008
SOURCE: No longer have access to making outbound calls after programming phone numbers
[Program] 99, [CO-01], 0, 01, [Store]
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Sep 03, 2009
SOURCE: in my firm i have panasonic kx-t7030x. for outside
A couple of ways. The system is probably a TA-624/824 box. In programming, you may have unassigned the lines on the set. That's checked by putting the switch in the back of the phone to PROGRAM, pressing the line buttons and reading the display. It will say CO 1, 2 3 etc. One of them will be missing, and it can be reprogrammed by dialing 0 + the missing number. Finish by pressing STORE and put the switch back to SET.
If that doesn't work, then you need to look in the Programming PM Manual and look at how to program the system. Program 400 sets the lines in use in a TA.
Of course you may have one of the other systems like a KXT-308 or 616 and this stuff may not apply :-)
Carl
Anonymous
  • 113 Answers
  • Posted on Mar 24, 2010
SOURCE: I need help setting speed dials on a Panasonic KX-T7730!!
Hello, from the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 001 and then SP-PHONE. Enter the system speeddial location ( 00 to 99 ) or just press SP-PHONE again to go to 00. Now enter your line access number ( usually 0 or 9 ) followed by the telephone number you would like to assign for the speeddial. Now press AUTO DIAL / STORE to save your setting. To go to the next speeddial location press SP-PHONE and follow the above steps again. Press Program to exit program mode. To dial the system speeddial from any extesion lift the handset and press * followed by the speeddial location ( example 00 )
PLEASE rate this answer if it was helpful.
Thank you.
5helpful
2answers
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    1helpful
    I have Panasonic kx-T7453 and one of the Outside lines was already connected to a station and while programming a One-Touch dialing ended causing the outside line to be disconnected to this station. How do...
    In a TD system, the lines have 2 digit number 01-12 normally, up to 55 actually. So, if line 1 is missing, press PROGRAM dial 99 press the unprogrammed button and dial 0 01 STORE
    Press PROGRAM or pick up the handset and drop it back down to exit programming.
    Carl
    1helpful
    How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
    The answer to the Caller ID question:
    Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
    The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
    Ther answer to the incoming call line ringing question:
    Again, depends on the system. For the Partner ACS:
    1) Press FEATURE 00 at extension 10 or 11.
    2) Enter the number of the extension to be programmed for Line Ringing.
    The green lights next to the line or pool buttons show the current Line Ringing settings for all
    lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
    light next to that button is off.) The following ringing options can be shown by the green light
    next to the line or pool button:
    ? Immediate Ring - on steady
    ? Delayed Ring - flashes slowly
    ? No Ring - flutters quickly
    3) Press the line or pool button until the button light shows the correct setting (the setting for the
    currently selected line or pool also appears on the display).
    4) Continue programming, or exit programming mode.
    Line selection:
    For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
    1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
    2) Enter the number of the extension to be programmed for Automatic Line Selection.
    3) Press **.
    4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
    Line Selection
    depend upon the type of extension:
    ? Key Extension: Outside system lines, Left Intercom (the factory setting)
    ? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
    setting), Pools 881-883, individual lines
    For each button pressed, a display similar to the following appears:
    5) To exit Automatic Line Selection, press **.
    6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
    Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
    Cannot get dial tone on KX-T7730. Intercom feature works fine.
    In a TA series system, the lines have to appear on the phone. Press PROGRAM and the CO buttons. Are they assigned? If they are, then you probably have a Class Of Service or Electronic Station Lock issue. Both of them would prevent the phone from getting an outside line.
    Carl
    We have an AT&T system with 4 lines and several MLS-12D phones. Two of our 4 lines are not working. If someone is on the main line, additional incoming calls do not roll over to the other lines. This...
    Changing programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
    next press the left hand intercom twice
    the display should say system programming
    enter in "#301"
    the display should say line assignment and station:
    enter in the station you want to program the line on.
    the display will then ask for the line number to program
    enter the line number you wish to program in 2 digit format i.e. line 1 is 01 and so forth
    the display should say Lxx and 2 not assigned
    enter 1 on the dialpad (assigned)
    repeat procedure for remaining sets
    enter feature "00" when finished
    1helpful
    I HAVE STILL GOT ALL THE SPEED DIAL NUMBERS IN MY TELEPHONE BUT SEEM TO HAVE LOST THE OUTSIDE LINE TO CALL ANYBODY, ALL I GET IS co NOT ASSIGNED, CAN ANYBODY HELP ME THROUGH IT?
    If your 773x phone is connected to most Panasonic systems, you can press PROGRAM and the place where lines are supposed to be assigned and it will tell you what's under the button with names like CO1, CO2, CO3 etc.
    If it says something else, you can make it become outside line access buttons by the command 0+a number 1,2,3 and STORE.
    You can do all 3 buttons at once, just keep pressing them and dialing the sequence with a STORE. After you've finished, just pick up the handset and drop it back down to end programming.
    Carl
    Tel KX-T7330
    The system that the 7330 is connected to controls how you program it and how it behaves.
    In the U.S. and for only a short time, the 7330 phones were connected to a TA-624. In fact, those phones were called "Euro Style" so you may be in the U.K.
    I don't recall if they have a PROGRAM switch in the back or a PROGRAM button on the face, but they are programmed with PROGRAM press the button you want to program and read the display.
    In Panasonic, all C.O. lines are assigned with 0 plus the CO number 1-6 in a 624's case and STORE. So you can reprogram the buttons in top to bottom or bottom to top order with 01 STORE 02 STORE etc. In passing, all extensions are programmed with 1 plus the 3 digit extension number as in 1101, 1102,1103 etc.
    If the puttons are physically sticky, you can use alcohol and clean them, or just reassign them.
    I hope this helps :-)
    Carl
    Programming Page Button
    You could look in the station user's guide and program paging. This may work, or not, if you're paging internal and outside do this:
    From your phone press Feature 00 the button and then Intercom *70.
    If you don't want all the idle phones in group 1, but just the outside speaker, press 70 alone.
    I'm not positive, but you may have to delete the button in centralized programming if it is already assigned a "CO" line.
    Centralized programming is done from extension 10 or 11 and involves the system manual and knowing where the overlay buttons are.
    Post back if you need a basic Partner ACS manual or try www.avaya.com for system manuals.
    Carl
    7helpful
    4answers
    We have the Panasonic KX-T7433 model of phones at our office. Yesterday I set about to re-programme some of the extensions and now, as a result I have lost the outside line for the phones that I have been...
    I just found this, which had the process for programming a CO button as a one-touch. And it worked. It's a bit easier to follow than the panasonic manual so hopefully it will have an answer.
    http://www.command-a.com.au/Portals/0/Panasonic%20816%201232%20Quick%20Referance%20Guide.pdf
    1helpful
    2answers
    Intercom
    Each of the six phones must have line 1 connected to the same "subscriber loop" (the same phone number). Assuming this is the case, and that you have not assigned any numbers to the the top six speed-dial buttons, each station will have agreed to be assigned a station number.
    From any station, pressing the speed-dial button for another station's station number will page that station.
    Now, how to properly initiate an intercom conversation differs between announcing to another station that a call is on hold, or a "cold call".
    Top Panasonic Lands Phones Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
