Question about Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television
RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
I HAVE A SAMSUNG HC P4752W REAR PROJECTION. THE RED CONVERGENCE ALIGNMENT SCREEN IS BOWING AND CAN'T BE ADJUSTED.BLUE, GREEN CONVERGENCE ADJUSTING SCREENS ARE FINE.ONLY VERTICAL ADJUSTMENTS CAN BE MADE IN RED CONVERGENCE. ALSO THERE IS A YELLOW TINT IN CORNERS WHICH DISTORTS COLOR.
Posted by unclegeo1949 on
Chi Chu
  • Samsung Master
  • 8,457 Answers
Try website Tv repair World.com to buy a whole convergence board for the replacement.The Akai/Samsung tvs used the same convergence board.
Posted on Apr 21, 2010
Edward
  • Samsung Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix hereRED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T AD - bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
I need the outer screen for my Samsung HC-P4752W. Mine has a red line that seems burnt into it. Where can I get one?
It sounds like the RED CRT is cracked which will cause a red line. You can verify by looking into the lens of the Red CRT with a flasnlight if you see a line the CRT needs replacement. If no line then chances are the Convergence IC may have a problem.
Sep 19, 2010 | Samsung HC-P4752W 47" Rear Projection...
Red and green arcs, 3-D effect
Convergence is dead.Know how to solders?Replaced 2 Convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.The shop will cost u $300 for parts and labors.
Jan 21, 2010 | Samsung HC-P4752W 47" Rear Projection...
SAMSUNG HC-P4752W 47" TV Convergence problem
Resistors most likey...look for burnt or discolored resistors near the convergence chips.
Apr 07, 2009 | Samsung HC-P4752W 47" Rear Projection...
Convergence problem Mitsubishi 6043
DOES IT AUTOMATIC CONVERGENCE,,TRY THAT,,IN THE MENU,,TRY NEW JACKS
Mar 27, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HDTV 1080I-Model#HCP4363W-Convergence Problem
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
Jan 21, 2009 | Samsung HC-P4752W 47" Rear Projection...
Green convergence not synced
I thing your problem is in convergence output it require Technicain job I can give part No. to order from Samsung but you still need to adjust convergence after you replace that part the adjustment require remote control and service manual and patient for instruction how to do convergence I can post it to you OK
now part No. is BP94-01259G or L
Nov 18, 2008 | Samsung HC-P4752W 47" Rear Projection...
I have a samsung hc-p4752w rear projection
Not simple at all it require a Technician yes it very common problem in the high voltage output you can replace the whole printer circuit board but it require to adjust a few thing after replace the new PCB such high voltage for 3 picture tube and convergence
Part No. is BP94-01249G or L
Samsung HCP4752W double vision
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung hc-p4752w
Sounds like convergence amp ic's
i dont have any part number for that model.
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Mar 14, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsung HC-P4752W 47" Rear Projection HDTV-Ready Television Logo
332 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
