Question about Sharp Wizard OZ-730
Want turn on
I have had my wizard for a very long time. I just replaced the batteries and when i hit the turn on button it want do anything it want come on or anything
Why would the anti-theft alarm go off?
Factory alarms rarely false alert, maybe someone did tamper with the car and ran off before you saw him. The one thing that will often trip alarms is a bad battery in the car, have it tested. Your car may have an add-on alarm in which case anything goofy can happen. It's odd that you had to hit the panic button to shut the alarm off, but if it functions normally otherwise it's unlikely to need a new battery. Is it at all possible that you hit the panic button and that caused the alarm to sound? If it was in your purse or pocket maybe it got pressed in which case it might be normal for you to have to hit panic again to turn it off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
Apr 07, 2015 | Lexus Cars & Trucks
I pushed the system wizard button on the dish remote and the remote will not work
The System Wizard button helps the remote store its settings inside the receiver as a backup, and then also backs up the receiver settings inside the remote, in case either needs to be replaced. It works best when you start the wizard while the remote is set down on a table or sturdy surface close to the receiver. If the remote won't leave the wizard, make sure you've exited all on screen menus (use the keys on the receiver) then remove the batteries. Replace the batteries after a short wait, but don't wait more than 5 minutes. After doing this, hit Sat, and the remote should restart.
Sep 15, 2014 | DISH Network IR Remote Control
How to rebot acer 4220 laptop
usually holding down the power button for a long time will force a reboot. I am not sure if that is what your asking
Dec 05, 2008 | Computers & Internet
Samsung YP-T10
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 28, 2008 | Audio Players & Recorders
Camera problem
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Feb 10, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Jan 20, 2008 | Pentax Optio M20 Digital Camera
Samsung S500 beeps and turns off when i hit shutter
If the Olympus is using the exact same batteries as the Canon, there is a high chance that the problem is with the batteries.
Dec 13, 2007 | Samsung Digimax S500 Digital Camera
Left connected when shutdown
This happens to me every other time I connect to charge the battery. I remove the screws on the back and remove and reinstall the battery then back to normal but still without a full charge.
Apr 12, 2007 | SanDisk Sansa e260 MP3 Player
Sharp Wizard OZ-730 Logo
Top Sharp Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
Robert Rankin
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
