I tested Display with 'POWER + D' and all colors is displayed. I tested RAMs with changing place and removing them but it doesn't turns on.
Drain the power from the laptop by disconnecting all sources of power including disconnecting the battery. Then press and hold the power button for 10 to 20 seconds. Then plug your power adapter in and power up the laptop.
Testimonial: "I did that but didn't turn on!? I opened my Laptop, disconected battery, left it for minutes and repeated the test no chenges happened."
SOURCE: i have a dell vostro 1500 laptop
This normally is an indication that the AC adapter is not powering the system and the remaining residual power in the battery only powers the system momentarily. Things to try:
Testimonial: "thanks for help i have a question dose bios failure due to virus cause this problem & how to program it"
SOURCE: VOSTRO 1320 doesn't turn on
That would leave the processor ic, usually most motherboards do not include that.
SOURCE: vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
