Question about Whirlpool RMC275PD Microwave Oven
What are the measurements - Whirlpool RMC275PD Microwave Oven
I also have a Daewoo Microwave oven that quit working and I need a replacement. What Make and Model can I get that will be the same size for my motorhome.
get a tape measure and measure thea external dimension of the dead microwave
go to a retailer and measure the dimensions of new microwave ovens and one with the same or slightly smaller dimension will fit in
the power or wattage of the unit is of little consequence but don't get smaller than what you had but a a bit bigger will be good
Jan 05, 2017 | Daewoo Microwave Ovens
GE Profile microwave oven PEB7226SFSS quit warming food but appeared to be on/operate with light on/timer counting down. Installed door switches-now the microwave "works" only when the door is open
Sounds like on reassembly you reversed wires to door switch.
switch might have letters C NO NC (common, normally open, normally closed) one wire goes to C common, the other to NC normally closed. Try reversing the wires.
If you use meter measuring continuity meter on C and NO should be high resistance until you press switch.
meter C to NC measures low resistance until you press switch then measures high or infinity (open)
Sep 28, 2016 | GE Microwave Ovens
What are the dimensions of a kenmore microwave with model number 565.66401690?
best bet is to take a tape measure and measure the width , the height and the depth, write down those measurements then go to an appliance shop and measure all those on display
Dec 09, 2015 | Kenmore Microwave Ovens
My kitchen aid micro wave stopped heating the food. Everything seems to be working. Model Khms155L. I want to replace it but it is no longer in production. Is there a replacement model that is an exact...
Take your measurements and compare them to the measurements from various microwaves online, then go to the store that has the same measurements. I wouldn't use the microwave for fear of a fire.
Dec 25, 2014 | Microwave Ovens
Good day,subject: LG microwave oven MS3448XRS not warming contents.Checked High voltage transformer 240 volt AC input-ok.Measure primary winding(0.2-0.4 ohm) measuring 1.1 ohm,secondary winding(70-100
Probably cheaper to buy a new microwave as they maintenance charge can be costly once put on a bench.
I am not able to help with this item.
Oct 01, 2014 | Microwave Ovens
What wattage is toshiba er6860w microwave?
You can do an exact power measurement by putting exactly
500 ml of water in a glass (Pyrex) or plastic measuring cup in the microwave. Measure the beginning temperature and record it, preferably with a digital thermometer. Run the unit on high for exactly 18 seconds. Use a digital watch or a stop watch, not the timer on the unit. Remove the measuring cup and stir the water to make sure that all the water is a uniform temperature. Record the temperature rise. Say the temp rise is 20 degrees Fahrenheit Multiply that figure by 38.75, this would indicate that the power delivered into the cavity is 775 watts. This is the old standard of measuring the power. The new standard called the IEC 705 would add 10% to that for a total of 852.5 watts. This matters more than the rating of the unit because if the power output is more than 15% below the units rated power, the magnetron is probably getting weak and needs to be replaced. Probably not worth the cost to repair. The voltage at the wall could also cause a low power output output. 'Google' the model # to see if you can find any info on this model #......
Nov 04, 2013 | Microwave Ovens
I just want a new one--what size replaces it
Take a measuring tape measure all four criteria, then when you go to buy, match the measurements on the box and have a salesman give you a hand so there can be no errors.
Apr 02, 2012 | Jenn-Air JMC7000 Microwave Oven
Measure microwave oven heating efeciency or effectiness
For 1 liter of water....run the oven for 60 seconds....then multiply the difference in temperature (the increase) by 35 to get an estimated output in watts.
There are variations on the procedure...this web site recommends a slightly different time and multiplication factor. This one describes a more accurate looking procedure.
Good luck...and I hope this is helpful!!
Jan 17, 2008 | Sharp R-820B Convection/Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Ekse
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
