Question about Konica Minolta 950-281 Genuine Konica Dv101k Bizhub 181/210/211 Di350/7115 Starter Developer
Error code c 2104 - Konica Minolta 950-281 Genuine Konica Dv101k Bizhub 181/210/211 Di350/7115 Starter Developer
  • Norman  J Weimar Jr
    Norman J Weimar Jr Jan 01, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Your problem is located under several different models which model do you have?
Minolta bizhub 750 error code c-2104 what is this problem
C - 2104 The transfer/separation cleaning home sensor does not turn ON when a specified period of time elapses after the transfer/separator cleaning motor starts the backward operation from rear to front.Remove the transfer/separator corona unit (2 screw) using a vacuum cleaner and clean the sensors(2 pieces located front and rear side.
Feb 22, 2013 | Konica Minolta bizhub C351 All-In-One...
Unerversal remote control codes for colby dvd
This remote control has no setup codes for Colby Tv.
Apr 21, 2012 | Radio Shack 15-2104 Remote Control
2006 ford f150 codes 2104 and 2112
2104 Throttle Actuator Control (TAC) System - Forced Idle
2112
Throttle Actuator Control (TAC) System - Stuck Closed
sounds like you need a throttle body
the pcm is seeing the
throttle plate is at a lower angle than commanded
Oct 17, 2009 | 2006 Ford F-150
I have a 2005 ford explorer, I got a code p2112 and p2104 what is this?
teck689- Your 2112 is throttle acutor stuck closed. This would be a problem with your throttle body. Your 2104 is a forced idle code. I would suspect that you were at one time unable to control the throttle after seeing that light. Your 2104 is set when the pcm sees a signal that does not match expected signal. dont chase the 2104 its set due to your 2112. Bottom line removed the throttle body which will be located at the end of the engine side of the intake tract. It should be held on with (4) 8mm bolts after you remove the hose clamp style clamp that surrounds the intake tract. WARNING: Do not I repeat DO NOT drop anything past that throttle body when you remove it. Go to a parts store pick up some "brake clean" clean and give both sides of the inside of that throttle body a real good and reinstall it. Make sure you remove any black build up which is carbon. That usually fixes it or at least buys you some time. If the light returns you will have to replace the throttle body. Expect to spend in the high 200's to low 300's for a new throttle body. good luck
Mar 03, 2009 | 2006 Ford Fusion
I have a rca universal remote control also a cody dvd player.
Hi freeent316,
Unfortunately, the RCA 15-2104 does not have a code for Cody brand DVD players. The list of codes can be found at the following web address:
http://support.radioshack.com/support_video/doc67/67141.htm
Since there is no published code for Cody brand devices, I recommend using the CODE SEARCH function. Here's how:
1) Turn on the DVD player
2) Press the DVD key on the remote
3) Hold down P until the red light blinks twice
4) Press 9-9-1 (the red light will then blink twice).
5) Slowly alternate between pressing the DVD key and the POWER key - when the device turns off, that means the remote has found a code for the DVD Player and should then operate it.
You can read the details about the CODE SEARCH feature in the user manual, which can be viewed at the following web address:
http://support.radioshack.com/support_video/doc66/66339.pdf
I hope this helps - please let me know if I can be of any further assistance.
Dec 11, 2008 | Radio Shack 15-2104 Remote Control
Can I use the Smart Remote 15-2104 for a Cyberhome DVD Recorder?
The product manual doesn't list the Cyber home product. You might want to try a code scan, that might turn up a code set that is close. Here are the instructions:
USING MANUAL CODE SEARCH
If your home entertainment device does not respond
to remote control commands after trying all of the
codes listed for your brand, or if your brand is not list-
ed, try searching for your code.
Follow these steps to search for codes manually.
1. Turn on the desired device.
2. On the 6-In-One Remote, press the appropriate
device key once.
3. Hold down P until the red light blinks twice.
4. Press 9 9 1. The red light blinks twice.
5. Aim the 6-In-One Remote at the desired device
and slowly alternate between pressing POWER
and the appropriate device key. Stop when the
device turns off — a working code has been
found.
Note: In the search mode, the remote sends IR
codes from its extensive library to the selected
device, starting with the most popular codes.
Because of the library’s size, this procedure may
take some time. When the red light blinks three
times, the search of every code is complete.
6. Press P once to lock in the code.
Mar 20, 2008 | Radio Shack 15-2104 Remote Control
Konica Minolta 950-281 Genuine Konica Dv101k Bizhub 181/210/211 Di350/7115 Starter Developer Logo
77 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
Marvin
Marvin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
