Question about Sony Cyber-Shot DSC-P150 Digital Camera
Sony DCR PC101-E
When I turn the lcd 180 degrees I do not see a mirror image, I see an image upside down.
I  also do not see an image when  the lcd is turned 180 degrees and pushed toward the handycam wall
Posted by sri71 on
  • 3 more comments
  • sri71 Oct 29, 2007
    Well I could do a self -shoot by turning the lcd towards me (180 degrees) and could see the mirror image, couple of months back. But now I cannot ........... I guess it it is to do with one  loose connection with my LCD PCB. Thanks for trying anyway.
    Oops Pro help sounds expensive....... Could you please suggest me one. Thanks
  • sri71 Oct 31, 2007
    Thanks Phillip
  • luizinhoalve Jun 24, 2008
    I have the same problem....how can I solve this??
    I have the same problem....How can I solve fix it???
Anonymous
    Champion:
  • 217 Answers
Your lcd flexwire  is bad, you need pro help to fix it.
Posted on Oct 29, 2007
  • Anonymous Oct 31, 2007
    Here in the philippines we are replacing these flexwire with the used laptop flexwire or you could solder or make a jumper wire to connect the  loose or disconnected line on flexwire.  (Flexwires inside these lcd screen body are composed of more than 20 small wires binded in heat resistant plastic. Magnetic wires no. AWG39 also is better than the original replacement, these two (laptop flexwires and magnetic wires) lasts longer than the original, but you have to be extra careful not to swap the wire connections.
Lyle Siemens
  • 328 Answers
That sounds perfectly normal as most cameras do that. You will find the reason for that as you get to use it more.
Display is upside down
hi,
it sounds like the tinny switch that detects the rotation of the LCD is blocked on the 180 degrees mode. it can be fixed but you need to disassemble the cam ! or may be try a little shock near the hinge... sometimes machines need a little kick !
Apr 04, 2014 | Sony Video Cameras
When I attempt to use my USB2.0 UVC VGA WebCam, the image that pops up is upside down.
There should be a setting in the camera software, that sets the mirroring or rotation of the image. Play around with the mirror-flipping options or the rotation factor to get the image right. If it's filpped upside down, a Flip Vertical should do, or a 180 degrees rotation.
If you find this post helpful and informative please vote with a Thumb Up. Thank you.
Jan 19, 2011 | ASUS K50IJ-C1 Notebook
I hv a dcr-pc101. Viewfinder and lcd display blank. Any Suggestion??? Pls help
The problem belongs to CCD IMAGER the part number is A1082392A. And for order please click here to see direct link.
thanks
Oct 26, 2010 | Sony Handycam DCR-PC101E Mini DV Digital...
Hp monitor
> how do I fix ?
Keep any "pranksters" away from your computer. :-)
The software for your video-card has an option to "rotate" the displayed image, either 90 or 180 or 270 degrees. Some "prankster" has set your video-card to the '180 degrees' setting. Change it back, or turn your monitor upside down. :-)
Apr 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Sony DCR-TRV25 when opening LCD panel turning upside down
my camera used to do that too as a matter of fact its just how some cameras are i used to be in a video class with cameras in high school and college , if you have to turn the lc panel the other way for it to work so the lcd panel must be turned away from you when your filming then to watch it you can turn it around i hope this helps you if not reply to me at Jonk3y @aol.com
Sep 23, 2009 | Sony Handycam DCR-TRV25 Mini DV Digital...
Upside down
Hi - I think you may have activated the "mirror mode" by rotating the LCD panel.
See page 33 in the manual:
You can download the manual from the link underlined in blue below:
DCR-SR50
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Jul 30, 2008 | Sony Handycam® DCR-SR50 Camcorder
Sony DCR-HC40 Viewfinder image is upside down
How did this happen?? I mean, all of a sudden you started gettin this image or after some repairs or you happen to drop the camera ??? pls specify.
Jun 20, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
LCD Screen Turns Blank with i rotate it 180 degress
Seems like the cable is damaged. You should get it fixed by SONY.
Feb 24, 2008 | Sony Handycam DCR-HC30 Mini DV Digital...
Image won't flip when the lcd panel is fliped to 180 degree i.e when i flip the lcd panel towards the lense to do a self shoot the image, instead of appearing stright appears upside - down
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. most probably the switch has worn out.
Aug 16, 2006 | JVC GR-DVL120 Mini DV Camcorder
Sony Cyber-Shot DSC-P150 Digital Camera Logo
Top Sony Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Harrie
NOEL
NOEL
Are you a Sony Camera Expert? Answer questions, earn points and help others
