Question about Pioneer AVH-P6500DVD Car DVD Player
My flap wont come out all the way - Pioneer AVH-P6500DVD Car DVD Player
I have a Holden Barina Hatch 2012 model.
I think the system on that car enables you to open the petrol flap once the drivers door is unlocked (either by pulling the cap open or pressing on the flap).
1. Lock the car using the central locking.
2. Insert the key on the drivers door, turn it once and unlock it. Open the door to check you have unlocked it. Then turn the key in the lock again as if you were unlocking it a 2nd time.
3. Now open the petrol flap as the lock should have released.
Jan 29, 2016 | Holden Cars & Trucks
My fuel flap wont open anymore
try see if flat head screw driver open flap door, wrap layer tape on flat head screw driver to keep damaging car paint.just pry little see if flap will open.
Sep 04, 2012 | 2002 Volkswagen Passat
Water comes from both the shower head and bath tub faucet when bath is turnd on and wont turn off when shower is on
if it is standard shower where you pull the knob up when water is running. the pull knob lifts a flap to shut off water to bottom faucet it proably has some buildup on the flap clean well with some clr or other calcium cleaner like it so the flap gets a clean seal on downspout
May 08, 2010 | Home
Shoot door (flap) for ice maker wont stay closed causing frost
the gear that pulls it closed is bad. some have small plungers instead of gears
Oct 28, 2009 | Refrigerators
Petrol filler flap stuck in locked position
you will need to force the flap open. inside there will be a bar that pops out to lock the flap. this will come off with 2 screws and will need replaceing.
Sep 25, 2009 | 2002 Isuzu Trooper
Battery flap wont shut
checkout any peice is broken. use quickfix solution, or better use solution tape
Jun 18, 2009 | Nikon Coolpix 7900 Digital Camera
Fuel flap wont open
YOU MAY BE ABLE TO TIE THE NEW ONE TO THE OLD ONE AND PULL IT THRU. DONT BE SURPRISED IF YOU FIND A BACKUP EMERGENCY CABLE IN YOUR TRUNK IN CASE YOUR MAIN CABLE BREAKS. ITS TYPICALLY UNDER THE CARPET.
Mar 16, 2009 | 1996 Toyota Camry
Inside air wont switch to defrost
Sounds like your selector flap isn't moving. It's either mechanically of vacuum controlled. If it's mechanically controlled, there's probably a small plastic clip that has broken causing the lever that moves the flap to come loose. If it's vacuum controlled, there's most likely either a vacuum line that has either come loose, or cracked causing a vacuum leak that's preventing the flap from having enough vacuum to pull the flap where it needs to be. Either way, you'll need to take off your dash cover and access the back of your heater controls to see exactly what is going on. Once you get in there, it should be fairly easy to detect your problem. Hope this helps! Have a great day!
Nov 23, 2008 | 2000 Mitsubishi Mirage
Pioneer AVH-P6500DVD Car DVD Player Logo
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
