U have to format your phone but before formatting backup all your contacts and data in phone memory because formatting erases all data in your phone memory
To format dial *#7370# A message will pop up restore phone settings select yes then enter the lock code your phone will be formatted. Hope this will help you. Please rate if you like the solution.
1) Factory defaults- Type *#7780# on your standby screen. This will reset all your setting to default factory settings. User data wont be affected. (Default Lock code is 12345)
2) Soft reset- Type *#7370# This will reset the phone as well delete user data. Use when want to format the phone.
There are three ways you can format your Nokia N79
To only remove settings and leave your applications and user data intact. Dial *#7780#
To delete contacts, messages, calendar events, applications installed to the phone's memory and all settings. Please note that you will need to format your memory using a computer to make sure that everything is deleted. Dial *#7370#
Bring it to Nokia Service Center to have it re-flash or reprogram.
Hi komal_74452.
Please follow the steps mentioned below to format the Phone Memory.
1) Please take a backup of all the Data before you format.
2) Performing the format will delete the Data in the Phone Memory.
3) To reset some of the settings to their original values, select (depending on your device):4) Menu > Tools > Settings > General > Factory settings.5) Menu > Settings > Phone > Phone mgmt. > Factory settings.6) To do this, you need the lock code.7) The default lock code is 12345.8) After resetting, the device may take a longer time to power on.9) Documents and files are unaffected. Hope this helps. Please feel free to contact for further information and assistance.
the default code is 12345. if this not works than you need to pull out the memory card and connect it wilth card reader, after that format it mannually
