you're facing with your Blomberg compact washer. Here are some steps you can try to reboot your washer after changing the main control board:
- Unplug the washer from the power outlet and wait for at least 5 minutes. This will allow the internal capacitors to discharge and reset the control board.
- After 5 minutes, plug the washer back into the power outlet and ensure it is properly connected to a reliable power source.
- Press and hold the "Start/Pause" button for at least 5 seconds to reset the washer. This may trigger a reboot of the control board and allow the washer to reset to its default settings.
- If the washer still does not reboot, you can try performing a factory reset. To do this, unplug the washer from the power outlet, and while holding the "Start/Pause" button, plug it back in. Continue to hold the button for another 5 seconds until the display shows "rES" or "rCL." Release the button and wait for the washer to complete the reset process.
- If none of the above steps work, you may need to refer to the user manual or contact Blomberg customer support for further assistance. It's possible that there could be other underlying issues that require professional diagnosis and repair.
Remember to always exercise caution when working with electrical appliances and consider seeking professional help if you're not familiar with the troubleshooting steps.
