Question about Epson Stylus CX6400 All-In-One InkJet Printer
Epson Stylus CX6400 not printing
My Epson printer which worked perfectly until recently , now doesnt even start up properly and a grinding noise comes from the unit (seems to be the belt that pulls the printing section along the rail). The message displays nothing useful - just to call technical support. Printer is over 3 years old and no warranty available. Any ideas ?
Posted by AndyG1 on
  • 8 more comments
  • Anonymous Nov 09, 2007
    I have an Epson CX6600. It was working perfectly fine until I turned it off. Now it will not print anything at all. It is connected properly to the port and everything seems fine except it will not print.
    Jim
    [email protected]
  • daveybaby Dec 29, 2007
    I put in new colour cartrage and it goes back an forth but its not printing on the paper
  • michmc Apr 09, 2008
    My Epson Stylus CX 6400 wont print just says printer error see your documentation and call service if necessary.
  • Anonymous May 19, 2008
    same problem
  • Anonymous Jun 12, 2008
    My Epson printer will not print. When I turn it on a grinding noise comes from the unit (seems to be the belt that pulls the printing section along the rail) the belt will go but the printing section will stay where its at and will not move at all. The message displays nothing useful the error states the following ERROR Printer error --> See your documentation and call service if necessary. Please any ideas ?
  • ecoporto Aug 28, 2008
    Same problem I guess.
    When top open: 1/2 second noise and then halts.
    When top close: makes a few more noises for 5 seconds.
  • bdiddy782 Oct 04, 2008
    prints blank
  • Anonymous Nov 06, 2008
  • sarakw Jan 04, 2009
    I tried cleaning the heads and check for paper, but could not find anything. Maybe it is best just buying a new one.?
  • Anonymous Mar 26, 2014
    I've tried holding the color b& w and stop button method but it doesnt work. Noise sounds like a tiny car starter motor trying to engage, a bit like the music fom '[email protected] the movie, eee, eeee, eeee, as he stabs her. All this is going on in my printer.
jpraspen
Where is this photo sensor
Posted on Jun 10, 2008
Ken Flack
  • 96 Answers
The head assembly is attached to a photo sensor that tells the printer when it is at the ends of its travel.
Sounds like this mechanism is not working properly.
Check to make sure thare is no obstructions or dirt in the paths at the ends of the print head travel.
You can use an air gun to clean the printer (JUST KEEP IT AWAY FROM THE PRINTER CARTRIDGES) as the ink will FLY EVERYWHERE.....
Posted on Feb 09, 2008
Anonymous
  • 154 Answers
Hi, below the belt that pulls the head from left to right is a 'bail bar' which the head moves along. Put a little light oiul on the bar, check for any bits of paper jammed in the mechanism which may be obstrucring the print head.
Also check that the bushes which support the print head haven't been dislodged. You can tell because there will be a strange looking doughnut type thing sitting and looking lost on the bail bar. you can usually just push this back into place on the side of the print head.
Posted on Dec 06, 2008
  • Anonymous Dec 09, 2008
    It's the brown ribbon like plastic strip just above the stainless steel bail bar
I put new ink cartridge and is not printing
clean cartridge if you are not active print docoments then change printer head
Oct 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Epson cx6400 injet printer "printer error"
Can you try a system restore. May be that will help
Oct 03, 2009 | Epson Stylus C43SX InkJet Printer
Epson Stylus Photo R300 sounds like it's printing
I know there are some cleaning cartridges with a chemical thinner that could clean any ink residual that could interfere with proper function of the printing head.
If this doesn't work you probably have to replace the head.
Check also the flat cable that follows the printing head during movement.
Fabio
Jun 16, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Inserting A4 paper
maybe this Site helps.
http://safemanuals.com/user-guide-instructions-owner-manual/EPSON/STYLUS%20SX100-_E
Here you can find many documentations e.g. for your Epson Stylus SX100
Jun 02, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Nothing prints out on paper.
Did you remove the little sticky tabs from each new cartridge? They allow air in, and ink out.
Have you removed the tear off tape from top of cartridges, it lets the air in and ink flows.
May 28, 2009 | Epson Stylus CX6400 All-In-One InkJet...
try doing 4 head cleans and then leave the printer powered up over night. Don't print or anything else after the head cleans until the morning then do one more head clean (this soaks the print head in ink overnight and then the final head clean should clear any obstruction. If the printer still refuses to print in colour, you could try replacing the cartridges anyway as they can be faulty. The only problem is thaty sometimes it's cheaper to buy a new priner. (how silly is that!) By the way, are you using compats or epson original ink carts?
Nov 03, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Prints blank page even when used by itself
weird, this problem accours almost only in lazerjets. anyway, you can try the following: 1. Unplug data cable. 2. plug power cord directly to socket (as opposed to extension) . 3. remove memory card. 4. changed toner cartridge. also, the info in the following page may assist you: http://support.microsoft.com/kb/q189764/
Mar 24, 2006 | Epson Stylus CX6400 All-In-One InkJet...
Epson Stylus CX6400 All-In-One InkJet Printer Logo
1,204 people viewed this question
Top Epson Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
