Question about Nordic Track NordicTrack Commercial 1500 Treadmill
How to remove belt - Nordic Track NordicTrack Commercial 1500 Treadmill
Accent broking timing belt now misfire 1&4
Lift the vehicle by using of jack.
Remove the engine support bracket.
Remove the power steering belt.Remove the air conditioning compressor belt.Remove the alternator belt
Remove the coolant pump pulley.
Remove the crankshaft pulley.
Remove the timing belt cover.
Move the timing belt tensioner pulley toward the coolant pump and temporarily secure it
.Remove the timing belt
Remove the camshaft from the camshaft sprocket
Remove the crankshaft sprocket and flange.
Remove the timing belt idler.
Remove the timing belt tensioner.
re install in reverse order. chances are the rod is bent but without breaking down the cylinder the only way to determine is to but a new belt on and see what happens. good luck.
Mar 11, 2013 | 2001 Hyundai Accent
Need to replace belt on cub cadet ltx 1040 drive belt and would like to find out how to do it?
REmove deck, remove crank pulley ( 5/8ths), remove belt from pulley, remove belt from transaxle pulley, then remove belt from crankshaft, remove belt from idler pulleys and remove from unit. Reinstall in reverse order.
Nov 23, 2012 | Garden
How to change the water pump? what has to come off first,second third etc.
I have a 1997 Rodeo so I'm not sure it is the same, but if your waterpump is located under the timing belt cover like mine is and is driven by the timing belt ...
1) Remove the upper fan shroud
2) Remove the (4) nuts then the cooling fan assembly
3) Remove the power steering drive belt
4) Remove the air conditioning compressor drive belt
5) Remove the generator drive belt
6) Remove the fan pulley assembly
7) Remove the crankshaft pulley
8) Remove the oil cooler hose
9) Remove the timing belt cover
10) Remove the timing belt pusher
11) Mark where the timing belt is currently seated in the cam and crankshaft gears (be real sure you know what you are doing here!!!)
12) Remove the timing belt
13) Drain the radiator
14) Remove the waterpump
Mar 01, 2011 | 1999 Isuzu Rodeo
Need diagram to put timingbelt on 2001 kia sportage
prev.gif next.gif Timing Belt Removal & Installation SOHC To Remove:
  1. Disconnect battery negative cable.
  2. Remove fresh air duct.
  3. Drain engine coolant into an appropriate container and retighten radiator drain plug.
  4. Remove upper radiator hose.
  5. Remove fan clutch assembly bolts.
  6. Remove 5 cooling fan shroud bolts.
  7. Remove fan shroud and fan as an assembly.
  8. Loosen alternator mounting bolts and remove drive belt from pulley.
  9. Remove fan pulley.
  10. Remove 4 cooling fan assembly bolts.
  11. Remove cooling fan assembly.
  12. Remove 4 bolts and upper timing belt cover.
  13. Remove 2 lower bolts and lower timing belt cover.
  14. Loosen adjusting bolt and remove A/C belt.
  15. Remove alternator belt.
  16. Loosen power steering pump lock bolt and mounting bolt.
  17. Remove drive belt from crankshaft damper. Camshaft timing marks kia-03-20-7032.gif
  18. Turn crankshaft until timing mark on front housing and the arrow "2" on the camshaft pulley align.
  19. Remove 5 bolts and remove damper.
  20. Remove timing belt guide from timing belt pulley.
  21. Loosen tensioner lock bolt.
  22. Pry tensioner away from timing belt and tighten lock bolt to relieve tension on the timing belt. NOTE: Mark the direction of timing belt rotation on the belt if it is being reused.
  23. Remove timing belt.
To Install:
NOTE: Timing belt pulley timing mark and timing mark must be aligned.
NOTE: The arrow at "2" on camshaft pulley must be aligned with timing mark on front housing.
  1. Install timing belt with minimal slack from timing belt pulley to water pump and from water pump to camshaft pulley.
  2. Loosen tensioner lock bolt until tension is applied to timing belt. CAUTION
    Do not turn crankshaft counterclockwise.
  3. Turn crankshaft pulley 2 full turns clockwise and ensure timing marks are properly aligned.
  4. Tighten tensioner lock bolt to 33 ft lb (45 Nm).
  5. Apply a force of 21 lb to timing belt midway between idler pulley and camshaft pulley.
    • Deflection should measure 0.43-0.51 inch (11-13 mm)
    NOTE: if timing belt deflection is incorrect remove timing belt and install NEW tensioner spring.
  6. Install timing belt guide.
  7. Install crankshaft damper pulley.
  8. Install 5 crankshaft damper pulley bolts. Tighten bolts to 132 in lb (15 Nm).
  9. Install power steering pump drive belt.
  10. Adjust power steering pump drive belt tension and tighten lock bolt and mounting bolt.
  11. Install alternator drive belt.
  12. Install A/C drive belt.
  13. Install lower timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
  14. Install upper timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
  15. Install cooling fan assembly and 4 bolts. Tighten bolts to 27 ft lb (37 Nm).
  16. Install fan pulley.
  17. Install fan clutch and shroud as an assembly. Tighten bolts to 74 in lb (8 Nm).
  18. Tighten 4 cooling fan nuts to 16 ft lb (22 Nm).
  19. Adjust alternator belt tension and tighten alternator mounting bolts.
  20. Install upper radiator hose.
  21. Install fresh air duct.
  22. Connect battery negative cable.
  23. Refill/bleed cooling system.
DOHC To Remove:
  3. Remove 5 cooling fan shroud bolts and 4 thermo-modulated fan nuts.
  4. Remove 4 thermo-modulated fan shroud fasteners.
  5. Remove generator drive belt.
  6. Remove fan pulley (located above crankshaft pulley).
  7. Remove 4 bolts and splash shield (located under front of vehicle).
  8. Remove A/C drive belt and power steering drive belt. Timing Belt Removal kia-03-20-7097.gif
  9. Remove 5 bolts and upper timing belt cover.
  10. Remove 2 bolts and lower timing belt cover.
  11. Loosen tensioner lock bolt and pivot tensioner pulley outboard.
  12. Retighten tensioner lock bolt. NOTE: Mark timing belt for rotation if it is being reused.
  13. Remove timing belt.
To Install:
  1. Align marks on timing belt pulley and pump body. Camshaft pulley alignment marks 79245g28.gif
  2. Align marks on camshaft pulleys with alignment marks on seal plate.
  3. Install timing belt. NOTE: No looseness should exist on the tension side and at the camshaft pulleys.
  4. Loosen tensioner lock bolt.
  5. Turn crankshaft 2 revolutions in direction of rotation and check that timing marks are still in alignment.
  6. Tighten timing belt tension lock bolt to 27-38 ft lb (32-52 Nm).
  7. Apply a force of 22 lbs to timing belt between camshaft sprockets.
    • Belt deflection should measure 0.30-0.33 in (7.5-8.5 mm)
    NOTE: Replace tensioner spring if timing belt deflection is excessive.
  8. Install lower timing belt cover.
  9. Install upper timing belt cover.
  10. Install power steering drive belt and adjust belt tension.
  11. Install fan pulley.
  12. Install generator drive belt and adjust belt tension.
  13. Install A/C drive belt and adjust belt tension.
  14. Install splash guard.
  15. Install fan and fan shroud.
  16. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  17. Install fan shroud mounting bolts.
  18. Install fresh air duct.
  19. Connect hose to resonance chamber.
  20. Connect battery negative cable.
Aug 02, 2010 | 2001 Kia Sportage
Timing belt replacement
Disconnect negative battery cable. Disconnect power
steering reservoir, and remove reservoir bracket.
Disconnect wire harness bracket for Data Link Conne
ctor No. 1. Remove generator and generator bracket.
Remove ABS actuator. Raise and support vehicle. Rem
ove right front wheel. Remove right engine
undercover. Remove power steering drive belt. Sligh
tly jack up engine and remove right engine mounting
insulator.
Remove spark plugs. Remove crankshaft pulley. . Remove right engine mounting bracket.
Remove No. 2 timing belt cover. . Temporarily install crankshaft pulley with pulle
y bolt. Set No.
1 cylinder to TDC on compression stroke. .
Loosen mounting bolt of No. 1 idler pulley and shif
t pulley toward left as far as it will go to reliev
e belt
tension. . Temporarily tighten idler pulley. Remove cranksh
aft pulley and No. 1 timing belt
cover.
If reusing timing belt, mark direction of rotation
on belt. Also place match marks on belt and camshaf
t
pulley. . Remove timing belt from engine.
NOTE:Always turn crankshaft clockwise.
Mar 18, 2010 | 1997 Toyota RAV4
Change timing belt galant 04 mivec 2.4
Timing belt “B” (balancer belt) and related components—2004–2005 Galant and 2004–2005 Lancer 2.4L engine
  1. Disconnect the negative battery cable. Remove the engine under cover.
  2. Remove the crankshaft damper pulley.
  3. Disconnect the control wiring harness connector, battery wiring harness connector and connector bracket to engine mounting insulator.
  4. Remove the harness bracket. Remove the upper timing belt cover. Remove the water pump pulley. Remove the idler pulley.
  5. Remove the auto tensioner. Remove the lower timing belt cover.
  6. Turn the crankshaft clockwise and align each timing mark to set the number one piston to TDC of its compression stroke.
  7. Remove the timing belt under cover rubber plug and then install special tool MD998738. Screw the special tool until it contacts the timing belt tensioner arm.
    NOTE The special tool must be screwed in gradually at the rate of a 30 degree turn per second. If it is screwed in all at once, the timing belt tensioner adjuster rod will not easily retract and the tool may bend.
  8. Gradually screw in the special tool and then align the timing belt tensioner adjuster rod set hole “A” with the timing belt tensioner adjuster cylinder set hole “B”.
  9. Insert a wire or pin in the set holes to lock the assembly in place. After removing the special tool, loosen the timing belt tensioner pulley mounting bolts and remove the timing belt. If the belt is being reused be sure to mark the direction of rotation (clockwise) on the belt.
  10. Remove the timing belt tensioner pulley, tensioner arm and adjuster.
  11. Remove the timing belt idler pulley. Remove the timing belt lower cover bracket. Remove the crankshaft position sensor.
  12. Remove the crankshaft pulley center bolt and washer. Remove the drive sprocket. Remove the crankshaft angle sensing blade.
  13. Remove the balancer timing belt tensioner. Remove the timing belt “B” (balancer belt) from its mounting.
Timing belt tensioner adjuster rod set hole “A” and cylinder set hole “B”—2004–2005 Galant and 2004–2005 Lancer 2.4L engine
To install:
Belt tension checking—2004–2005 Galant and 2004–2005 Lancer 2.4L engine
Cylinder block plug location—2004–2005 Galant and 2004–2005 Lancer 2.4L engine
Timing belt sprocket alignment—2002–2004–2005 Galant and 2004–2005 Lancer 2.4L engine
Feb 27, 2010 | 2004 Mitsubishi Galant
Serpentine belt diagram for 1996 audi a4 quattro v6. I can't find a proper diamgram and install procedure, can you help?
Ribbed Belt: Service and Repair
Ribbed Belt, Removing and Installing
Ribbed belt, removing and installing
CAUTION: Mark the direction of belt travel before removing, using a crayon or marker. Reinstalling a used belt in the opposite direction
could damage the belt
Note:
There are two different types of ribbed belt, identified as versions A and B.
Ribbed belt versions, identifying, refer to Application and ID
Removing
Old version A
- Remove ribbed belt guard.
- Loosen ribbed belt tensioner using 15 mm wrench and drift 3204.
- Remove ribbed belt.
New version B
- Using 10 mm hex socket wrench, turn downward in direction of arrow to loosen ribbed belt.
Installing
Install in reverse order of removal, noting the following:
- Place ribbed belt over drive pulleys and idler roller first, and onto tensioning roller last.
- Remove drift 3204.
- Install ribbed belt guard.
Sep 24, 2009 | 1996 Audi A4
How to change engine belts on a jaguar x-type 2003 3.0
To Remove BELTS : Drive Belt :
Disconnect battery ground cable
Remove wheel and tire
Detach accessory drive belt
detention drive belt
detach accessory drive belt
Remove accessory drive belt
slacken the tensioner
remove accessory belt drive
WATER PUMP BELT : Remove battery tray
Remove water pump belt
De-tension water pump belt
Installation in reverse
Hope this is helpfull
Jul 11, 2009 | 2003 Jaguar X-Type
I need instructions on replacing the timing belt
1. Remove the Alternator Belt.
2. Remove the Water Pump Pulley
3. Remove the Air Conditioner Belt and Power Steering Belt.
4. Remove the Crankshaft Pulley.
5. Remove the timing belt cover
6. Remove the timing belt tensioner pulley.
7. Remove the Timing Belt.
8. (If Replacing) Remove Idler Pulley.
Installation is reverse of removal. Keep a close eye on the timing marks on the cam sprockets to make sure you don't knock anything out of whack.
I would strongly recommend replacing the water pump while you are replacing the timing belt. (The water pump usually comes in the timing belt kit.) Otherwise you are going to have to do this all over again when your water pump goes out. Good Luck.
Nov 10, 2008 | 2004 Hyundai Tiburon
Seat Belt repair/replace
  1. Remove front seat.
  2. Remove adjuster cover. A
  3. Slide floor anchor cover.
  4. Remove floor anchor bolt. B
  5. Remove shoulder anchor bolt. C
  6. Remove front and rear kicking plate, then remove center pillar upper and lower garnish.
  7. Disconnect seat belt pre-tensioner connector.
  8. Remove the screw securing seat belt pre-tensioner retractor, then remove seat belt and seat belt pre-tensioner retractor.
  9. Remove bolts securing seat belt adjuster, then remove seat belt adjuster. Reverse procedure to install.J
Nov 03, 2008 | 2000 Nissan Maxima
Nordic Track NordicTrack Commercial 1500 Treadmill Logo
52 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
stargajzer
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
