go to settings-> do not disturb and make sure do not disturb is off, you can also check to see if do not disturb is on by seeing if there is a moon in your status bar
Question is kind of Vague, so I'm assuming you are trying to turn off the Do Not Disturb (DND). In the standby mode, press the do not disturb button on the base. The DND indicator will light and DO NOT DISTURB shows in handset display. To cancel, press the do not disturb button again. Hope that helps.
Attendant To apply Do Not Disturb on an extension: • Press the DO NOT DISTURB function key or dial *85. The LCD shows EXT-NUMBER ?. • Dial the desired extension number. • Press the DND ON softkey. • If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension. • Press the EXIT softkey. To remove Do Not Disturb on an extension: • Press the DO NOT DISTURB function key. The LCD shows EXT-NUMBER ?. • Dial the desired extension number. The LCD shows the extension number and DO NOT DISTURB. • Press the DND OFF softkey. • If desired, press the NEW EXT softkey to apply or remove Do Not Disturb on another extension. • Press the EXIT softkey.
It's pretty straightforward. You pick a spare button, dial FEAT 00 press the blank button (with a light) and press FEAT 01. There are considerations that I'll reproduce here.
Do Not Disturb (F01) 8
Use this feature to be able to press a programmed button to prevent incoming calls for the
extension from ringing (lights still flash). When Do Not Disturb is on, outside callers hear ringing
while inside callers hear a busy signal. You should use Do Not Disturb only if someone answers
outside calls for your extension when you do not answer them.
Considerations 8
■ Do Not Disturb is available only on system telephones.
■ Do Not Disturb requires a button with lights. When the Do Not Disturb feature is on, the light
is also on, indicating that the telephone will not ring.
■ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
to transfer calls to you.
■ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
the Hunt Group will skip your extension and ring immediately at the next available extension
in the group.
■ To avoid missing calls when Do Not Disturb is not needed, turn it off.
■ If Do Not Disturb is active at a doorphone alert extension, the person at the doorphone hears
signaling, but the alert extension is not signaled.
■ Unanswered calls that are transferred from an extension with Do Not Disturb active ring at
that extension if they transfer return.
■ Extensions with Do Not Disturb activated do not receive Caller ID information, unless the call
is answered.
■ Users with Automatic VMS Cover Assigned or with VMS Cover turned on can activate Do
Not Disturb to Send All Calls immediately to their voice mailbox.
■ Users with Call Coverage turned on can activate Do Not Disturb to Send All Calls
immediately to the covering extension.
■ You cannot use Call Screening (F25) when Do Not Disturb is turned on.
From the manual: You need to program a button with FEATURE 01.
¦ Use Do Not Disturb when you do not want the auto attendant or the voice messaging system
¦ Use Do Not Disturb if you are assigned to a Hunt Group and you leave your desk, so calls to
in the group.
¦ To avoid missing calls when Do Not Disturb is not needed, turn it off
DND Allows you to mute the ringer on all handsets.
In the standby mode press the do not disturb button on the base the DND indicator will light and DO NOT DISTURB shows in the handset display.
To cancel press the do not disturb button again.
For GE 6.0:
There is a button on the base (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
1. Pick up the phone handset and dial *98. 2. Press 2 to disable Do Not Disturb. 3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
For GE 6.0:There is a button on the base lower right corner (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:1. Pick up the phone handset and dial *98. 2. Press 2 to disable Do Not Disturb. 3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset. Hope this helps!
For GE 6.0: There is a button on the base (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz: 1. Pick up the phone handset and dial *98. 2. Press 2 to disable Do Not Disturb. 3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
