Question about Riccar Vacuums
Will not start
Plug in flip switch and will not turn on
Thatvacguy.com
  • Riccar Master
  • 1,604 Answers
First check the reset button on the back
Posted on Jan 13, 2015
Kirby G4 was surging, then a flash of light and a pop from outlet!
the surge is caused by a faultering armture, might be caused by low carbons or sticking carbons, strip the motor down for inspection. Or take it to your local kirby service centre shop for clean and service and polish. price range from 39 to 59
Jul 07, 2017 | Kirby Vacuums
Rug shampoo machine keeps blowing breakers now will not power on
It sounds like you have a dead short. Check the wire, it quite often will break at the point that it comes out of the machine. The power is going straight back to the panel before it gets to the motor and that flips the breaker. It probably needs the whole wire replaced. If you can take it apart, check with an ohm meter to see which wire it broken. Do not have it plugged in while doing this.
May 10, 2015 | Vacuums
The switch on my machin will not go on what do i do their or whats wrong with that what do i do to fix it?I plug in the rug doctor then i flip the switch but it wont go on.
bad switch or broken wire in the cord . use a continuity tester to check from the plug to the switch. if the cord is good check the switch itself good luck
Apr 27, 2015 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
How to put a switch in or do i need new one
By the question you asked I assume it wont power on. More than likely its not the switch . More likely its the power cord because it get most of the abuse. you will need a meter in any case to find out . If you don't have a meter you can pick one up for under $10 at any hardware section of most Dept store chains. A good investment. turn the meter to the omega symbol Looks like an upside down horseshoe with feet. touch the leads together meter should zero. place the probes across the end of the power cord plug. One on each tab. watch the meter and flip the switch while holding the plug and probes together. if the meter doesn't move the switch is probably ok. usually the cord plug or the strain relief going into the machine wares out but check the cord for cuts or unusual ware first. if you dont mind a few inches missing remove the bad area of cord and replace. to verify its the swich or not pull the unit apart and put the meter leads across the switch and toggle the switchthe meter should change from zero the some high number. Good luck have fun and learn !
Nov 22, 2010 | Bissell 6594 PowerForce Bagless Upright...
Beater attachment has no suction.
Your hose issue is isolated from the garage. You have a switch problem in the handle of the hose.
If the hose has a swivel handle your problem will lie in the switch itself or the contact rings within the lower portion of the handle itself. If this is a light gray hose with swivel handle several years old switches were an issue from time to time . The problem can normally be fixed by replacing the internal wiring harness in the hose.
Oct 03, 2009 | Easy Flo EF1600 Central System Vacuum
When I plug my vaperetto it trips the socket switch
Presume you mean it flips a breaker. There is short in the vac. Given that it uses water it should go to a certified repair shop.
Aug 24, 2009 | Vacuums
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Won't turn on after flipping over
get back to me on your problem with model number. i might have another solution! GETERDUN
Dec 13, 2007 | Kenmore 22812 Bagged Canister Vacuum
My 2month old hoover bagless stopped working completely!
I found out there was a large dusty clog in my vacuum. I had to clean it out then leave it un-plugged for quite a long time.
There is an automatic shut-off on the vacuum so it doesn't over heat and it won't turn back on it you don't leave it un-plugged and cleaned out.
Mar 30, 2007 | Hoover U8147-900 WindTunnel V2 Bagless...
Vacuums Logo
41 people viewed this question
Top Riccar Vacuums Experts
brian kossman
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
