Question about HP LaserJet 2605dn Printer
Laserjet 2605 49 error - HP LaserJet 2605dn Printer
John Cole
    Sergeant:
    Champion:
  • 237 Answers
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Posted on Nov 26, 2014
Error b0605
HP laserjet p2055dn error message B0605
Jul 05, 2012 | HP P2055DN LaserJet Monochrome Printer
HP Color LaserJet CP1515n Printer is showing error 51.23. please help
error 51.23 on the hp color laserjet cp1515n printer. please help
Apr 28, 2011 | HP Office Equipment & Supplies
My hp Laserjet 3330 Had error 79
Firmware error. Unplug the power cord. Wait 30 seconds. Plug it in, power it on. If the error comes back, you will have to upgrade the firmware.
May 20, 2010 | HP LaserJet 3330 All-In-One Printer
Hp laserjet m1522nf 10.0000 supply memory error
Are you using HP toner? Try reseating the cartridge. If it's still getting the error, replace the cartridge.
May 20, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
Feb 23, 2010 | HP Laserjet M2727nf Multifunction Printer
Scanner error 6
Problem for HP LaserJet M1120 MFP All-In-One Printer Scanner error 6
Feb 22, 2009 | HP LaserJet M1120 MFP All-In-One Printer
Printing Problem
GO ON LINE AND TYPE INTHE FOLLOWING INFORMATION; EXAMPLE:
HP LASERJET 4250N PRINTER ERROR MESSAGE KERNEL
ENTER
"" "" "" ILLEGALOPERTORSEQUENCE
ENTER
HP LASERJET 4250N ENDCHAR ERROR
ENTER
HP LASERJET 4250N PRINTER POSITION 24 ERROR
ENTER
HP LASERJET 4250N ERROR MESSAGE [ CODE # ]
ENTER
ROD THE CANDYMANGANDY
Dec 20, 2008 | HP LaserJet 4250n Printer
Error 51.23 on HP 3600 color laserjet printer
Aug 12, 2008 | HP LaserJet 3600n Printer
618 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
