Sony Walkman WM-D6C Personal Cassette Player Logo
A
Anonymous Posted on Mar 10, 2014
Program buttons on keyboard are hard to press
Keyboard in case stopped working
Are you talking about the keyboard on the device itself. If so I did a hard restart on my device and it came back on. Press the power button and the volume button on the low setting. This should be a hard reset. Then use the volume up button to scroll to the reset and it will hard reset hopefully reseting your keyboard
3answers
Adjust letters repeating
Key could be stuck on keyboard. Try banging on all the keys (not hard enough to break - just hard enough to unstick). Try a different keyboard.
Unistall windows 8 pro
You have to install another operating system
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
or
Formatting a hard drive to erase its contents does not mean the files are necessarily gone forever. Using data-recovery software, someone still could retrieve sensitive data and files from your hard drive even after you've formatted it. Instead of simply formatting your hard drive, use disc-cleaning software to permanently erase its contents. Disc-cleaning programs work by repeatedly overwriting the contents of a hard drive with random data patterns, making it virtually impossible to recover the original files. Download and install the freeware program Active@ KillDisk (see Below). http://www.killdisk.com/downloadfree.htm Click the Windows "Start" button and select KillDisk from the "All Programs" list. Click the check box next to the hard drive you want to erase in the "System Local Disks" menu. Press the "Kill" button. Select the erasing method you want to use from the "Erase Method" drop-down menu. Active@ recommends using the "US DoD 5220.22-M" method. Click "Start" to begin erasing the hard drive. Download and install the freeware program Hard Drive Eraser (see Below). http://www.harddriveeraser.org/ Click the Windows "Start" button and select Hard Drive Eraser from the "All Programs" list. Check the radio button next to the hard drive you want to erase under "Select Drive to Erase." Select the erasing method you want to use from the "Shredding Scheme" drop-down menu. The developers of Hard Drive Eraser recommend "DoD 5220-22 M" Press the "Start" button to begin erasing the hard drive. Download and install Iolo DriverScrubber (see Below). Click the "Windows" Start button, "All http://www.iolo.com/ds/3/ Programs" and then the DriverScrubber program icon. Click "Wipe all contents of a drive," and then click "3.5-Inch Floppy Disk." Insert a blank floppy disk and click "Next." Restart your computer with the floppy disk still inserted. Your computer will boot directly to DriveScrubber. Press the down arrow on your keyboard to highlight the hard drive you want to format in the "Available Physical Drives" menu. Press the space bar to select the hard drive. Press "Enter" to continue. Press the down arrow to highlight "Seven Overwrites" in the "Available Data Wiping Methods" menu, and then press the space bar to select it. Press "Enter" to continue. Press "CTRL," "ALT," "Shift" and "W" at the same time to wipe the hard drive. Hope this helps.
b>
1helpful
I have the Logitech EX100 wireless keyboard and mouse. We had to change the battery as it went dead. Now that we have new batteries in we cannot get them to work. Any suggestions?
Do a Hard Reset method to clear the keyboard and mouse settings and reconnect it back to your computer:
• Remove the batteries from the keyboard
• Press the Connect button on the receiver for 10 seconds.
• Press the Connect button on the mouse.
(You might need a pencil tip or other small tip to press the connect button.)
• Insert the batteries back into the keyboard.
• Press the Connect button on the receiver.
• Press the Connect button on the keyboard.
Hope this helps
Please rate this solution, thanks!
How to print screen
On the right of the keyboard you have Print Screen SysRq button,press that button
go to start all programs /paint,start paint aplication and press ctrl + V.
5helpful
3answers
Print screen doesn´t work
If the print screen button doesn't work, try to use Alt + Print Screen. If that doesn't work either, then try to re-install the software that came with your keyboard (if there is).
However, for most multi-media keyboards and mice, the CD that comes with them usually made to program the special buttons only. But I'm not sure in your case. There could be an option for you to re-program the buttons on your end, including the Print Screen button.
But if there's no way to re-program it and the Alt + Print Screen didn't help, then you may want to send the keyboard to the reseller or manufacturer for repair. It's a hardware defect.
Thank you and good luck!
1helpful
I have a logitech Ex100 mouse/keyboard set & both have just suddenly stopped working. It tells you how to re-start the system by pressing 'connect' on the reciever & then the mosue &/or...
Help hard drive is down fron pressing pc buttton
Your computer is in STAND-BY position..
RE-PRESS the same button, and your computer will be back to normal
GEPower Keyboard Help - Worked before, but not now
Did you install the CD software program for the Keyboard?
The Keyboard should have been plugged in before you started your computer. Then you should have installed the CD program.
Also after installation if it doesn't work try the following:
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
3helpful
2answers
Gateway cordless KR-0401 Keyboard
I had the same problem. I solved it by pressing the connect button on the back of the keyboard and then pressing the connect button on the wireless connection base. The keyboard and the base will sync up again. Should solve your problem.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
