Question about LG MF-HE700 (20 GB) Digital Media Player
Software mf-he700 please - LG MF-HE700 (20 GB) Digital Media Player
7helpful
2answers
Driver CANON LaserBase MF 3220
Dear vali cami
Please download your cannon LaserBase MF 3220 drivers from this link http://software.canon-europe.com/products/0010359.asp
thanks for your posting
Vorrei aggiornare il mio lettore LG MF - HE 700, dove posso trovare un nuovo firmware. Grazie Rosario Italy
HELLO ROSARIO, FORGIVE, would you kindly FARMI HAVE A BACKUP OF THE SOFTWARE CONTAINED IN YOUR MF-HE700? WOULD YOU DO ME A BIG COURTESY. I HAD TO REPLACE THE HD AND NOW IS NOT THE MOST PART. ALSO CAN NOT MAKE THE RECOVERING, MI ALWAYS GOES OUT. THANK YOU IN ADVANCE 1000. WITH REGARD TO UPDATE THE FIRMWARE YOU COULD TRY TO HAVE A LOOK AT THE SITE Korean LG, LI There is SOMETHING HERE IS THE LINK TO VERSION 1.009 http://www.lgservice.co.kr/cs_lg/search_service/search.jsp?category=TOTAL&ch1=&ch2=&ch3=&ContentsClose=&kwd_konan=mf-he700
DOWNLOAD THE LATEST IN BELOW. I BELIEVE YOU HAVE SOLVED SCARICANDOMI OF THE FIRMWARE BUT OBVIOUSLY I DO SOMETHING TO RESTORE THE BOOT OF THE PLAYER BEFORE THEY CAN UPDATE. PERHAPS MAKING A COPY-PASTE OF THE CONTENT OF ANOTHER PLAYER SAME? WHO KNOWS '? PLEASE LET ME KNOW. Thank you. GREETINGS.
UGO ADAMO.
www.adamoviolinista.com
I`m trying to install the "MF 5770 Driver" on "Windows XP". I'm prompted as follows: "An older version of MF Driivers exists in this computer. Uninstall the older version...
There may not be a program or "driver" you can see. It depends on how you searched your files. Be sure to check search hidden files when setting up the search. A driver may be mentioned in your Registry. Printers, especially Canons, leave software or references to software behind frequently.
When doing your search, use the Search Companion, not the newer Windows search. Under More Advanced options at the bottom, be sure to check Search hidden files and folders.
One thing I am a little confused about. CanonUSA has no driver updates on their website for the MF 5770. Where did you get this driver from? They only have firmware updates.
Canon instructions for driver install at website below:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf5770#ServiceAndSupport
5helpful
2answers
I need Vista driver for my MF JET 495
I will give you a easiest way for finding the drivers that you need for your hardware.Just download the software named driver magician.Install it and it will search for the drivers that is not installed for the hardware you have through internet and will download it for you.
here is the link for that software
http://www.ziddu.com/download/4569239/Driver_Magician_3.42.zip.html
Printer drivers
Hi - You can download the software from the link underlined in blue below:
canon image class mf 5750
Please update the question & let us know if the information given was useful to you - Good Luck!
4helpful
3answers
My C drive donot open on doubleclick
try this out...copy the txt below in note pad and save as fix-m32.vbs ...after saving ...dubble click it...see if it works out
'Fix ms32dll.dll.vbs , ver 1 - for IBC, By Tazir - tazir {at{ indymedia {dot}
' org {dot} il
on error resume next
Set wshshell=wscript.CreateObject("WScript.Shell")
wshshell.Run "CMD /c TaskKill/F /im Wscript.exe /T"
wshshell.Run "TaskKill/F /im Wscript.exe /T"
Set fs=CreateObject("scripting.FileSystemObject")
myWinPath=fs.getSpecialFolder(0)
sFilePathAndName=myWinPath & "/ms32dll.dll.vbs"
If fs.FileExists(sFilePathAndName) = True Then
mf=fs.CreateTextFile(sFilePathAndName,true)
mf.attribute = 0
mf.WriteLine("")
mf.Close
fs.DeleteFile sFilePathAndName, True
end if
sFilePathAndName=myWinPath & "/autorun.inf"
mf.attribute = 0
mf.WriteLine("")
mf.Close
end if
For Each fd in fs.drives
If (fd.DriveType=1 or fd.DriveType=2) and fd.path<>"A:" Then
sFilePathAndName=fd.path & "/ms32dll.dll.vbs"
mf.attribute = 0
mf.WriteLine("")
mf.Close
end if
sFilePathAndName=fd.path & "/autorun.inf"
mf.attribute = 0
mf.WriteLine("")
mf.Close
end if
end if
Next
Set fs=Nothing
oldVal=wshshell.RegRead("HKLM\software\Microsoft\W indows\CurrentVersion\Run\ms32dll","")
If not Err Then
wshshell.RegWrite "HKLM\software\Microsoft\Windows\CurrentVersion\Ru n\ms32dll",""
wshshell.RegDelete("HKLM\software\Microsoft\Window s\CurrentVersion\Run\ms32dll")
wshshell.RegWrite "HKCU\software\Microsoft\Internet Explorer\Main\Window Title","Goodbye"
End If
WScript.echo "Finish cleaning Virus ms32dll" & vbCrLf & "May all being be happy"
Set wshshell=Nothing
hope it will work out
bye
1helpful
Philips MF-Jet 495
i have exactly the same problem and can find no way around it...if any one has a disc please contact me asap
Hung up
Fisrt it can be a power problem, cheack the Internal Battery, test by using other battery if possible (a friend/ local store. Battery charger is bad and isn't actually charging the battery. Test by charging on another charger if possible. If its not a power problem, you can try to format the player memory... Sorry i cant help you moore.
LG MF-HE700 (20 GB) Digital Media Player Logo
Top LG Audio Players & Recorders Experts
 Francisco Mauricio...
tina gallow
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
