Question about Electronics - Others
My 8gb usb is lighting but cannot be access - Electronics - Others
Posted by Pablo Jr. Presto on
Gerry Johnson
Initially, I thought my USB drive is not properly connected and because of that unable to access data. But, the problem is even after proper insertion of USB drive unable to access data. To overcome such issues, use Remo Recover tool to recover data from corrupt USB drive.
Posted on Mar 12, 2014
When My 8gb drive is connected then notification given is USB device is malfunctioned and windows does not recognize it. So it does not allow me to get access so give the appropriate solution
Click Start, type Device Manager in the Search box
Click Device Manager from the returned list.
Click Disk Drives from the list of hardware
Right-click the USB external hard drive with the issue, and click Uninstall.
After the hard drive is uninstalled, unplug the USB cable.
Wait for 1 minute and then reconnect the USB cable. The driver should automatically load
Check for the USB drive in Windows Explorer
Dec 26, 2013 | Kingston 8GB Data Traveler - 108:...
My 8GB transcend USB got wet. Will I be able to use it again?
yes , you can use infrared light or ultrasonic machine, or use rice in recipient and put your 8gb transcend USB and let them by 24 hours, for dry it.
God bless you
Oct 29, 2013 | Transcend Electronics - Others
I can't access my transcend 8GB pendrive.and light is not blink.what to do?
go to http://www.transcend-info.com/Products/online_recovery_2.asp?LangNo=0
Jul 17, 2013 | Transcend Electronics - Others
I have a 8gb flashdrive for a xobox 360 and i cannot access it no matter waht i try and for some reason it doesn't even light up what do i do?
Are you trying to use it as a memory card? TO do this you need to format it. If the light's not coming on it could be that the USB port is broken.
Apr 23, 2012 | Video Game Consoles & Games
Can't access
It looks as if the flash drive has items loaded but when I try to view it says nothing is on the flash drive.
Most confused,
Frank
Dec 01, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My 8gb sandisk cruzer does not light up anymore and is not recognized.
SaveMyUsb.com can recover data from most damaged and faulty flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 29, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Lexar 8GB wont work. when i insert it, it shows up on my computer as connected but then when i click on the lexar icon to view my files on it, it doesn't open, the message: 'please insert disk into drive...
Some computers will not support a large 8GB stick. The best some will do is 2GB, If you are running a computer pre-2001, you may not be able to use the 8GB stick (I have the same problem with my desktop PC). It just is not supported!
Oct 05, 2010 | Lexar Professional High-Speed 2GB Secure...
My 8Gb Tevion USB drive shows No Media
Try this , it has worked freat on my drives
Super Stick Recovery Tool V1.0.2.19.rar
http://www.mediafire.com/?81t60ysdvquymsq
Jun 30, 2010 | Electronics - Others
Is this compatable w/windows 7?
The Short Answer to this is Yes. I have one and it works perfectly fine in windows 7. The only thing that does not work is that actual cruzer software itself. By this i mean that little window that comes up on xp comptuers. However you can still access it under my computer and you can still stop the device on in the tray icons. I hope this helps
Thanks
Steven.
Apr 26, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Access data on 8Gb SD card
Some older card readers will not read the newer HC-SD cards all memory cards larger that 4gb are HC-SD. You need to get a new card reader that states HC-SD compatible. Office Depot sells them as well as many online sites. Then just plug the new reader into a USB port and go.
I Hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 23, 2009 | Electronics - Others
Electronics - Others Logo
Top Electronics - Others Experts
Tom Chichester
Bill Boyd
Are you an Electronics - Other Expert? Answer questions, earn points and help others
