Question about Acer Iconia Tab A200-10g16u XE.H8QPN.001 Tablet - Android 3.2 Honeycom
Not internet access
No internet access.
Posted by Luis Zuniga II on
  • MrLego423
    MrLego423 Jun 24, 2014
    Hi Luis Zuniga II, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Bhabotosh Chakraborty
    New Friend:
  • 138 Answers
You need to connect right data card which support your set then net connection will able.please help by donate some $ Please Help Me To Get Out Of Debt
Posted on Jul 13, 2014
My antie gave me a kurio 10 s table and it keeps saying no internet why and what should i do to fix it please
Hi Rachael,
How to configure the internet access for Kurio 10s.
The internet access must be configured for each profile separately. Through the Parental Area / Profiles, choose the profile to configure.
In the main profile menu, chose Internet Access Modes:
- No Internet Access: No Internet access is allowed from the tablet. Apps can still access online content if an Internet connection is active.
- Restrict Web Browsing to Specific Sites: Restricts Internet browsing only to websites that appear on the Safe List of this profile. All other sites will be blocked.
- Kurio Genius™ Filtering System: Our advanced filtering system allows users to browse the Internet safely by blocking websites that may contain inappropriate content.
- Full Internet Access: Removes any and all restrictions to web browsing. Not recommended for a child user profile.
I hope this helps, Mikey
How can i connect my tablet to wifi without a house that dos not have Internet access in county wexford ireland.
Are you trying to just connect to wifi to access a local network or are you trying to access the internet? If you just want to connect to a local network, maybe to access other devices on the network, you would need a router broadcasting the network that all the devices connect to. If you are only trying to get access to the internet, consider purchasing a hot spot device. It will provide cellular type service and will broadcast a wifi signal that you can connect your tablet or other devices to for internet access. Hot spots will cost you a monthly fee for the service and you will have to purchase the device itself. Another possibility is to use your cell phone as a hot spot and tether the tablet to it. Just remember whatever data you use on your tablet will be charged to your data plan on your cell phone. On my nexus 5x phone, it's fairly easy to turn on (settings, under wireless and networks select more, select tethering and portable hotspot, turn on portable wifi hotspot, set a password if you want to). Once turned on, the phone will broadcast a signal that you can connect other devices to for internet access. Some cellular providers don't allow tethering. If that is the case with yours there are some apps that will still allow you to set up tethering such as AndroidTethering or Easy Tether. In the past, I've had some trouble connecting wirelessly using the apps and found that using USB tether options worked better for me.
2answers
Is there a way I can get free access on my ipad mini
Theres only three ways to connect to the internet depending on the iPad you have.
Wifi
4G (If you have a 4G iPad)
Hotspot from your phone. Most phones can share your data and create its own wifi network, sharing it to your iPad.
Claims do not have internet access when it shows in notifications, will not load at origin.
Test your device at a hotspot. Setup internet access in setting.
If with free cab't get access, your wifi adapter is not working and if device is in watrranty, should be repaired
Why am I unable to access the internet?
Take your tablet to a HOTSPOT with free WiFi and try to access Internet there. If can't, it's because inbuilt wireless adaptar has some problem.
It says that I have internet but cant get on the internet
Do you try to connect to the Internet when at home or away from home ? At home, you need to have a wireless (WiFi) network to connect your tablet to and then access the Internet from your tablet. Away from home you need to find an OPEN WiFi network (usually in public places such as coffee shops, bookstores, etc) to connect to. Or you can get an USB mobile/cellular modem from your cellular provider to attach to the USB port on your tablet and access the Internet at home and/or away from home (this option will cost you money). You also need to install on your tablet apps that will access the Internet (browsers, Pandora, Youtube, etc.).
Why won't my 7DRK go on to the internet/?
Has the device previously been able to access the internet....or is this is new device that you are trying to connect with? You may need to setup the tablet to access your wireless router. Most are password protected and this must be set up before network and internet access are permitted.
1helpful
I can't internet on this computer
This looks to be a WiFi only tablet. Do you have a WiFi access point to connect to or have a free one somewhere like WalMart/MickyDs etc. You then need to make sure your WiFi is turned on your tablet and then connect to the access point. Once connected you can use a browser to access the internet.
Can't access internet
Did you try uninstalling the app to see if that was causing a problem? If that doesn't work, is it your network that isn't working or just your device?
I accidently deleted my browsing history from my archos 10-1 internet tablet. I have android stored. Is there a way to retrieve that browsing history? Thnaks in advance
1 Select "Tools" from the browser toolbar and then choose "Internet Options."
2 Click "Settings" from the General tab.
3 Go to the toolbar menu and then select "View Files."
4 Locate the file under the desired field heading, either "Name," "Internet Address," "Type," "Size," "Expires," "Last Modified," "Last Accessed" or "Last Checked." (Note: You can click on the arrow within the "Last Accessed" field header to sort the list from either the earliest or most recent files accessed.)
5 Right-click on the file and then select "Open in New Window."
Acer Iconia Tab A200-10g16u XE.H8QPN.001 Tablet - Android 3.2 Honeycom Logo
Top Acer Tablets & eReaders Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
NOEL
NOEL
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
