Question about HP Deskjet 3510 e-All-in-One Printer
KEEPS READING OUT OF PAPER
There IS PAPER BUT ITS READING OUTOF PAPER
Posted by Brit Brat on
303 Electronics
  • HP Master
  • 347 Answers
Posted on Oct 09, 2019
Pete Fotheringham
    Novelist:
  • HP Expert
  • 175 Answers
The hp deskjet do not have a paper empty sensor, and so reply on attempting to feed paper upto three attempts are made if on the final attempt the paper path sensor still reads zero then the report is 'no Paper'
Posted on Mar 11, 2014
Brother printer keeps reading "no paper".....it has paper in it.
try paper in mp tray if that works your bottom tray may not be lifting
May 18, 2010 | Brother MFC-8860DN Printer
My printer keeps saying there is a paper jam. But
If the printer is sensing a paper jam, then there is either a small piece of paper jammed under a sensor, or the sensor is falsely reporting a jam.
If you cannot find the sliver of paper, I suggest that you contact Canon Technical Support or take the printer to an authorized repair shop.
Don
Oct 17, 2009 | Canon Office Equipment & Supplies
DOES NOT PRINT ALL OF A SUDDEN STOPPED PRINTING AFTER RAN OUTOF OF PAPER.PUT IN MORE PAPER, PRESSED "PRINT" NOTHING HAPPEN HP S
Hi dep209
Clear all the documents in the printer queue. To do this go to the printer folder.
You can do this going to the Control Panel
Click on Printers
Click on the name of your printer to open the folder
If few documents are listed there cancel all of them.
Then turn the printer of and on again
Now try to print
Hope this will help you.
luciana44
Oct 04, 2009 | HP Office Equipment & Supplies
The laser jet outof paper
sensor in dust, clean with vaccum cleaner
Jun 16, 2009 | HP LaserJet 1018 Printer
Error message about toner
There is no counter on the machine. Toner is recognized by a sensor within the machine that measures density. There is a malfunction. Only way to repair is have it checked /replaced by a tech.
Apr 22, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Paper jam
I would make sure you opened and closed EVERY section of the machine that was indicated on the op panel.... even if you found the paper already..
Apr 11, 2009 | Office Equipment & Supplies
Paper feed
check to make sure there isnt a foreign object in the paper feeder. Had the same issue awhile ago and found that the kids put a toy in it.
Nov 11, 2007 | Lexmark X1150 All-In-One InkJet Printer
Paper feed
I cannot get the paper to feed in straight. What should I do? Thanks
Aug 28, 2006 | Dell A920 InkJet Printer
HP Deskjet 3510 e-All-in-One Printer Logo
efs_perpends
efs_perpends
k24674
