Question about Radio Communications
Yaesu ft 1000d
Low sensebility in rx
    Master:
  • 623 Answers
Be sure the RF gain is turned up, if it is and there's still low RX sensitivity, it probably has lost the GASFET transistor in the front end.
Posted on May 19, 2014
4 Suggested Answers
6ya staff
SOURCE:
Chuck Badeaux
  • 95 Answers
SOURCE: INTERCHANGE MODULE
I'm gonna go out on a limb here and assume you are talking about the band modules, right? If so it will accept some in the 6m,2m,and a couple of the 70cm bands. The model numbers I know it will accept are as follows: FEX-767-2,-6,-70A and -70B. If your module is one of these they are interchangeable. BTW, all of these modules are presently discontinued I'm sorry to say. Hope this helps!
Posted on Mar 28, 2009
Gerard
  • 211 Answers
SOURCE: yaesu ft 1500 m
Here you can see the schematics http://www.repeater-builder.com/yaesu-vertex-standard/ft-1500/ft-1500m-sch.pdf
The manual can be found on the Yaesu website, http://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=106&encProdID=92FB2363C1E0B9EBC9D3479054E0120B&DivisionID=65&isArchived=1
Good luck,
Gerard
Posted on Jan 30, 2010
Ironfist109
Iron
  • 3018 Answers
SOURCE: Yaesu 1000d blows power supply fuses. Worked night
  • This radio is a base radio that does not run off a DC. Not sure what fuses you are refering to because the power supply is internal. The FT-1000 is one of my favorite radios. My friend has one I DX on sometimes. A fuse in general blows from a direct short. If this is the case then you want to check the wiring being used to supply the power feed.
  • I have the service manual in RAR form if you would like it. Let me know.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Oct 04, 2011
What is the cause of higher fuel consumption of 2002 rx 3oo? my car is just a year old in my hand although is a tokumbo
Past due for a tune-up? Dirty fuel injectors, clogged catalytic converter, dirty/clogged air filter, low tire pressure, transmission fluid low...? Dirty fuel filter?
Mar 02, 2016 | 2002 Lexus RX 300
Stuck on rx mode
Rx is an abbreviation for receive. (Tx is transmit) There are a variety of reasons a radio will be "stuck" in Rx:
1) Another radio in the group is stuck in transmit and you cannot reply if your radio is receiving the other radios transmission.
2) Your radio is programmed for Rx only.
3) Your radio has a Tx problem such as a bad mic, or something covering the mic opening.
4) Your battery is low or bad. It takes more energy to Tx than to Rx.
Best regards.
Feb 07, 2014 | Cobra LI3900-2DXVP (14 Channels) 2-Way...
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
How to reset tire pressure light on for Rx 350 2007
The tire pressure is low then required. Make sure you have checked the tire pressure on all 5 tires. Yes i said 5, including the spare tire. If the spare tire pressure is low then also the light will also come on. ---------- Click this link below to get more details:--- http://technoanswers.blogspot.com/2011/10/tire-pressure-light-on-for-lexus-rx-350.html ----------- This should help.Thanks.Helpmech.
Oct 10, 2011 | 2007 Lexus RX 350 FWD
The manual did not come with my lexus rx 350....it now has a exclamation mark with parenthesess around it. what does it mean?
Looks like an exclamation mark inside a horseshoe with a ridged bottom = low tire pressure
Oct 05, 2010 | 2008 Lexus Rx 350
Timing chain wearing out
It has a timing belt.
May 31, 2010 | 2001 Lexus RX 300
The drivers side low beam was out so I replaced
there is a fuse for each side of the headlights check for a blown fuse.
Jan 29, 2010 | 2001 Lexus RX 300
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
Yamaha RX-V861 Low frequency "flutter" after turning on
How close to your video monitor is this rxr? It is not shielded well as far as sync circuits in your TV are concerned. Refer to manual...accordianman
Apr 03, 2008 | Yamaha RX-V661 Receiver
Radio Communications Logo
89 people viewed this question
Top Radio Communications Experts
Anthony Ward
Anthony Ward
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
