Computers & Internet Logo
Debbie Connell Posted on Mar 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cdr how to
How do I watch a cdr on my computer that somebody gave me
Robbie Sleepy Whitworth
Level 2:
Sergeant:
  • Expert 248 Answers
  • Posted on Mar 12, 2014
Expert
Level 2:
Sergeant:
Answers
248
Questions
Helped
50630
Points
728
Vostro 1500 compaq cdr dvd player not work
Replace the CD/DVD player -- less than $20 for a new one.
Take the old/broken one to the computer-store, to get a new one with matching power/data connectors.
4helpful
Error reading problem in x6 , i tried to open it in other computer as well but it shows the same problem for my .cdr file...
At problem opening in other computers evidently .cdr file is invalid. Make use of cdr repair
http://www.coreldraw.repairtoolboxx.com article helps you to successfully open the file
1helpful
How do I delete photos from my Sony MVC-CD400 Camera CDR-W disks?
Insert the CDR-W disk into the CD drive in your computer and then format the CDR-W disk.
2answers
Guys..need help...bumili ako ng CDR-KING ROUTER CW-8196..nadedetect ko ung wifi signal pero walang internet access. pero pag direkta sa LAN ung net ko.malakas naman net ko..windows 7 gamit ko...
DUDE..simple lang yan...if meron ka modem...off mo muna modem..
tapos..un-install mo yung "ETHERNET ADAPTER"
den...from Modem connect mo to CDR-king Router - PC, tapos " restart "
and MAGIC...OK na NET MO..pati WIFI...
1helpful
Unable to burn CD
The CDR that your usin was already been used thats why you received that messae try to use a new CDR and burn a file see if it will works
*You can also use CDRW (Rewritable) so that you can use it multiple times unlike CDR you can only burn once :)
2answers
What is a M.cdr file and how can I burn it to dvd to watch on dvd player?and the same for a dmg file?
Detailed information for file extension CDR: File classification: Graphic Mime type: application/cdr, application/coreldraw, application/x-cdr, application/x-coreldraw, image/cdr, image/x-cdr, zz-application/zz-winassoc-cdr Identifying characters: Hex: 52494646, ASCII: RIFF
Program ID: CDraw4 , CorelDRAW.Graphic.8 , CorelDRAW.Graphic.9 , CorelDRAW.Graphic.10 , CorelDRAW.Graphic.11 Associated links: XnView Other applications associated with file type CDR:
  • Elite Plus Commander Saved GameThe Identifying characters used for this association are:Hex: 45 4C 49 54 45 20 43 6F 6D 6D 61 6E 64 65 72 20 46 69 6C 65 1A , ASCII: ELITE.Commander.File.
  • Final Cut Pro CD/DVD Image File by Apple Inc.Final Cut provides Mac users editing tools, sound design, real-time motion graphics and DVD authoring. CDR files are ISO images and, if moved to a PC, can be renamed and burned as ISO files. Associated links: Ken Stone's Final Cut Pro Website
  • GameJack Virtual CD or DVD Image by S.A.D. GmbH.Appears to be an older extension. GameJack seems to use .XMD now.
  • Raw Audio-CD Data
  • Sound File This association is classified as Audio. Associated links: Linux Player
The DMG file type is primarily associated with 'Macintosh OS X' by Apple Inc.. On the Macintosh, these files are treated like a real disk. They can be created with Disk Copy, burnt to CD or mounted as a normal volume. The DMG file also comes in different formats: HFS, HFS+, UFS, ProDOS, Linux, and Fat32 and so may also require special mounting software to account for the format. IsoBuster can interpret these files directly as can other programs such as UltraISO. The program TransMac, by Acute Systems, can both open and create DMG files on a PC.
Daewoo vcr/tv combo 13HIFC watch one channel-tape another channel
somebody on the radio said there is a site called Tech(something?).com which gives instructions... I can't remember the word after Tech
Problem with my cdr4170
can i connect cdr 4170 to my tv screen?
Phillips cdr 785 audio recorder will not record. i am using digital audio cdr blanks.unit is 6 years old...has not been recording for 3 years.
time to buy new one or upgrade software
new cd/dvd formats came out maken it hard to play record or watch on outdate equipment
they remolded the cd/dvds with a new gloss
RCA CD recorder/player CDRW120
You sure it's recognizing the CDR? And you are using 'consumer audio' cdr? Watch it at all times. If it 'opc fails' after you put a blank in it still shows as a CDR and 0:00 on the display but won't record. It's easy to miss.
Grand Canyon Tech
Grand Canyon Tech
