Type: 2000 Mitsubishi OBD P1400
There is a lot for you to read
Then have a repair shop properly test the vehicle
& make the repairs
The free code read at the parts store is a waste of your time
If you want buy a cheap code reader at auto zone, but understand why you have it & study OBD2 Systems & it will only read Generic Codes & a few others,always need professional software to look at data,road test with it & more
Codes usually have nothing to do with the need to install parts
You can have codes stored,lots of them & no check light on
your dash,you can have problems & no codes, but need the scan tool & other reference material & test euipment
SOURCE: 2000 Eclipse GT auto trans.
thats one of two things i had the same problem with my 94 honda civic and my 00 mitsubishi eclipse both were not cheep to fix saddly for you man on my civic my tranny was catching and it would stall the motor out idk if that was the complete problem because i sold the car the same day i found out and i do not talk to the guy i sold it too but i seen it running fine a week or so later and on my eclipse it was my ecu for some reason there was a defect or some wires touching or something like that they replaced all my wires and my ecu and it ran fine till i sold it for my 2007 mitsubishi eclipse and gladdly i have not had any problems scince i bought the car
SOURCE: 2000 Mitsubishi Eclipse GT horn not working
check the wires to the clip on the horn they rust and then there no connection
SOURCE: 2000 mitsubishi eclipse gt radio code problems
Get your VIN and go to a dealership. If you ask real nice they will probably give you the code to unlock your radio for free.
SOURCE: 2000 eclipse gt getting a po1400 code and car does
PO1400 is not a common code. PO140 however is. PO140 is a oxygen sensor problem, it refers to bank 1 sensor 2 having no activity. This could cause your eclipse to not hold a good idle and possibly to stall. I would have a different mechanic check the car before you spend quite a bit of cash on an ECM as they can cost upwards of 800 dollars
SOURCE: 2002 eclipse spyder gt has
I'm having the exact same codes on my '01 GT. http://www.club3g.com/forum/problem-reports/112664-p0403-exhaust-gas-recirculation-circuit-malfunction.html
check out the last post on that page. literally just got done getting the "BB" out of the tubing. haven't found out if it solved that problem yet, but I'm hoping to not have to change the solenoid.
I'm still working on the P0128
