Question about Denon Audio Players & Recorders
New Denon AVR-E400 runs very hot and shuts itself off.
New Denon AVR-E400 runs very hot. After playing Pandora for a few hours on both Zones 1 and 2 at a moderate volume, it shut down. Box was very hot. Let it rest about 10 minutes and turned on again and shut off again 15 minutes later. It seems like it is running too hot and the receiver goes into protect mode and shuts itself off. The receiver is sitting on top of an entertainment center with plenty of room on all sides to breathe. This problem NEVER occurred on my old Denon AVR-888 with exact same inputs and speaker setup. Beyond this problem, I love the receiver. Waiting for Denon to call back after I explained to them the situation. Any thoughts?
Posted by Gordon P on
5 Related Answers
jt085
jt085
SOURCE: Denon AVR-1803 keeps shutting down
I had a similar problem with my Denon receiver... I thought there might be some issue with the power source, which was a (supposedly good quality, surge protected) power strip that it was sharing with a lot of other gear.
I unplugged it from the power strip, and ran an extension cord from the next room and plugged it into that.
The switching off & on seems to have stopped.
Posted on May 18, 2012
Anonymous
  • 67 Answers
SOURCE: Denon AVR-1803 shuts down
I am a Tech in Michigan and have worked on lots and Lots of Denon AV Receivers. These units have Protection circuits for Overcurrent, Dc Protect, 15v Regulator inbalance, Rail Voltage Inbalance, Low Ac Voltage, Low Standby Voltage and Thermal Protection just to name the ones I remember. My guess is you Probably have either Poor Intermittent solder connections or Amp is not Ventillating Properly. Make sure you leave room above Receiver to Vent and You are using no Less then 6 ohm speaker Impedance per ch. Refer to Speaker Impedance chart on back panel . [email protected]
Posted on Jan 05, 2008
Anonymous
  • 624 Answers
SOURCE: Shutdown protection? HELP please
All of the Denon recievers I have repaired (over 100) that shut down after a very short time are going into protect mode. The display lights up and after about 10 seconds the display goes out and the standby led blinks red.
I have found that they have one of 3 possible problems and they all require that the reciever be taken apart and fixed at component level. No way to tell what your problem is until it gets put on a bench and troubleshot.
Problem 1. This is the most common problem. One of the front channels shorts out. On the big heat sink the front channels are at each end. It is the front left channel (close to the display) This requires that the output transistors be replaced as well as some driver transistors and some resistors and a capacitor. Lots of work for a blown channel. Denon has put out a bullitin to upgrade the bias transistor and change a couple of resistors to help compensate for this failure. That channel overheats more than any other channel.
Problem 2. There is a resistor that is right next to the preamp board that opens up. It is a 10 ohm 1 watt resistor and when it opens, it causes the unit to go into protect.
Problem 3. The +12 volt regulator fails. It is in the power supply area on a smal heat sink right next to the -12 volt regulator. Generic part number is KIA7812 It also causes the unit to go into protect.
Most decent repair shops can fix these from about $120 up to about $200. Depending on which problem it is and how fast they are at finding the problem. Most charge labor by the hour.
Posted on Jun 18, 2008
ABRsvcs
  • 4234 Answers
SOURCE: denon avr-2106 getting hot shutting down
Normally when this happens it is because the impedence load is too small. This unit requires 8 Ohm speakers. If you connect 4 Ohm speakers, it will work, but work harder and generate excessive heat. If the heat is too much, the unit will enter protect mode and shut down. Once it cools off, it will work again. In your case, if the speakers are the correct impedence, check for crossed wires. If that is the problem, running the unit at higher volume levels should cause it to shutdown sooner.
Keep us posted,
Dan
Posted on Mar 10, 2009
mattvierra
Matt Vierra
  • 75 Answers
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF] AVR-3300/1 3.3E*
Posted on Jul 22, 2009
Denon receiver AVR X2000
On the Denon website they had a similiar complaint about Spotify. They suggested rebooting the receiver by unplugging it and then plugging it back in..
Have you made any changes to your router or modem? They may need a software update.
Sep 22, 2016 | Sony Audio Players & Recorders
How to connect a denon avr-e400 receiver to a televion
If the DENON has an HDMI output, and your TV has an HDMI input, then use a HDMI cable. Then, use the TV's remote-control to select "source" (or "input") as 'HDMI 2' or 'HDMI 3' (assuming that you have been using 'HDMI 1' to watch TV).
Feb 08, 2015 | Denon AVR-E400 7.1 Channel 4K and 3D Pass...
Sound stops when listening to Pandora via Samsung LED Pandora App.
Is the TV connected to the receiver with a digital connection (coax, or optical)?. Try setting it to PCM on the TV Some receivers don't like it when there is a break between tracks and the signal is lost. You won't get surround (but Pandora is just stereo anyway), but you can still use the Receiver's Dolby or DTS features to go multispeaker. Downside if of course that if you have other Multichannel audio sources through the TV, they may be lost. But it's worth checking..
May 13, 2014 | Denon AVR-E400
My denon 3313 will not play the channels from my pandora account it sees my play channels it wont play them
Have you checked to see if there is a firmware update? You might need to reset back to factory but you will loose any items you put in.
Factory reset by:
1 Turn off the power using ON/STANDBY.
2 Press ON/STANDBY while simultaneously pressing PRESET CHANNEL 2 and PRESET CHANNEL 3.
3 Once the display starts flashing at intervals of about 1 second, release the two buttons
Mar 26, 2014 | Denon AVR-3313CI
Pandora activation code
From Denon website!
http://usa.denon.com/us/news/pages/newsdetails.aspx?newstype=news&newsid=89&year=2012
Dec 01, 2012 | Denon Avr-1913 - 7.1 Ch. 3d Pass-through &...
Unable to play pandora on Denon 1912
Check the Denon website. There is a notice for Pandora users. Pandora changed something and Denon products are blocked as of 11/30. They state that they are working on a fix and to check back after 12/6 for the update.
Dec 01, 2012 | Denon AVR1912
Denon AVR-2309C1 will not play sound through
Turn off zone 2 then turn your receiver on the main zone on Radio, tune in a station and check for audio. Post a comment and let me know if audio works that way. If you don't have any audio, list your other equipment makes and models as well as how they are interconnected to your receiver (cable type) and I will help you troubleshoot
Jun 28, 2009 | Denon AVR588 Receiver
Denon avr-2106 getting hot shutting down
Keep us posted,
Dan
Mar 10, 2009 | Denon AVR-2106 Receiver
Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
May 24, 2008 | Denon AVR-1803 Receiver
1,311 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
