You will need to change the programming for the ext that you want to have the lines appearing on.
Enter programming - Feature **266344
PW - 266344
Press the show key - (top right arroe that is lit on the display)
Enter the ext # you want to change
this will bring you to line appearance press top r arrow
line assignment press top right arrow
show line - enter 001,002 or whatever line(s) you want to ring.
press the change softkey for each line to appear and ring instead of unassigned. Press the next (bottom r arrow) to go through each line after entering 001....
then release.
*** Make sure the sets you change are not forwarded to voicemail after a certain amount of rings otherwise all calls ringing on the newly programmed set will go to that persons voicemail.
SOURCE: My Nortel Meridian M2008 phone will not ring
it may be turned down to low.press the program key and use the scroll bar below the keypad to find your option...hopes this helps
SOURCE: change extension number on Nortel T7316E model
Well ~ eagleeigh731 has it mostly correct, do what he said to do and get into the programming --> find SYSTEM PRGRAMMING --> hit next until you find CHANGE DNs--> OLD DNs (this is the old extn#) 222 then type in NEW DN 431--> then hit the end or release button.
Voila your new extension is now there... to check dial FEATURE 0 then press the intercom button, the new extension should be there.
SOURCE: My phone won't quit ringing
Keep looking under Terminals and Sets for your extensions. Lines either Appear or Appear and Ring.
Carl
SOURCE: changing name in nortel T7316E handset
We would like to change the name displays on our phones
SOURCE: Handset will not work
Try swapping the handset and cord with a working phone. Those handsets are known to loose the transmitters. As for the ringing, have someone make an intercom call to your extenxsion. Do not answer the call...while the light is flashing press the volume up button several times. www.dyna-tech.us
Hope this helps
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to
temporarily turn them off use do not disturb (feature 85, feature #85 to
turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310,
...regards John
