Nothing else to add
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
SOURCE: onkyo tx-sv727 Protect displayed
first thing if it says protect, check the fuses inside the system they may of blown .When choosing wire gauge, consider the quality of your components and speakers, the overall sound quality you're trying to achieve, and the budget you're working with. Also, keep in mind the distance between your receiver or amp and your speakers long wire runs can cause significant power losses, and thus require thicker cable. You can use this as a guideline
Distance from speaker to amplifier Gauge
Less than 80 feet 16
80 to 200 feet 14
More than 200 feet 12
SOURCE: Righ & Left Front speakers not functioning
SOUNDS LIKE HE HIT YOUR SPEAKER CHANELS 1 OR 2,,, PUSH 1
There are
a number of different reasons why your computer may no longer give sound. If
you have this problem, read on to learn how to diagnose the problem and resolve
your PC's loss of sound.
Check the Speaker Connections and Volume Control Settings
Perform a System Restore If Necessary
Delete and Reinstall the Original Sound Drivers
I hope this information will be helpful. Thank you for using FixYa!
