My rv air condition wont work on high. could it be the blower .at low it works ok just not as cold.
Fan should be on auto
Could be the selector switch turn off power switch low and high wire if it blows high replace selector switch if it does not work replace motor. Tom
FIXED 1996 CEILING ac/fan only run on low, not high. Someone had wired the control knob wrong. 6 pin unless you have a heater # 3 should be empty. # 1 black, # 2 red, #4 purple. Left one pin is live. The high wire was on the heat wire. This did affect the thermostat performance and the motor over heated and shut off on fan only. $1000 later and over 10 hours on the roof. 2 min fix. Grrrr
