Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Location of reset button on a WD65737
Where is the reset button on my tv so that I can reset it???
Posted by mel brenden on
Goodman Custom Design and Installation
  • 139 Answers
Right next to the other controls on the TV, it is recessed so you will need a paper clip or ball point pen to press it.
Posted on Apr 18, 2014
Won't turn on! No green light to show that it has turned on.
look for a tiny hole in the button panel. It may or not be marked reset. Straighten out a paper clip and push it in the hole slowly until you feel it stop. Gently push it to reset the TV. If that doesn't work, then look at the lamp cover door to see if it is closed all the way. The switch may be bad too.
May 29, 2016 | Mitsubishi WD65737 65 inch DLP 1080p HDTV
Lg 42px-4dv/ea sustain pcb fails after 6 hrs running.
Try hard resetting;
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
Figure 1: Example of the reset button labeling on the LC2600N
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Jul 21, 2008 | Televison & Video
Sanyo Service Menu - Factory-Reset.com
factory-reset.com/wiki/Sanyo_Service_Menu
Jump to Sanyo TV Service Menu Method 2 - Unplug the power cable. Press and hold the {VOL -} button on the TV while plugging the power cable back ...
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... I have a Sanyo TV, I accidentally hit the reset button twice. I ...
Aug 6, 2012
36 inch sanyo tv won't change off video 2?
Apr 17, 2010
I accidentally hit the 'reset' button the remote of my sanyo tv ...
Jan 6, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
Nov 29, 2015 | Sanyo DS31520 31" TV
Wd65737 Mitsubishi 65 in dlp tv, Does not go past blue welcome screen
Can you call up the settings menu? Check to see if the ANT-1, DVD, and other ports are properly activated. You may need to re-scan for channels and to activate the HDMI ports for your other devices. Regards.
Aug 13, 2015 | Mitsubishi WD65737 65" DLP TV
Tv turned itself off and started blinking red light. i unplugged tv and waited and then plugged back in and waited for the blinking green light to go off. turned tv back on and it worked all day. today...
Try removing the projection lamp and reinstalling it. After you reinstall the lamp look for a small reset button near the projection lamp compartment. Could be on the right or left side.
Apr 12, 2014 | Mitsubishi WD65737 65" DLP TV
Cannot get AV Mode
There is a TV/VIDEO button on frond panel of the tv. When you press each time this button then you will able to access different video inputs. if the button is inactive the probably the micro switch for TV/VIDEO button may be faulty. also check the same with the remote. If its doesn't help then try to reset the tv to factory default setting. For that you need the remote. Keep in mind that when you reset the tv to factory default setting all the memorized parameters will erased(like channel memory, personal preference setting etc ). For reseting the tv to factory default do the following
1.Turn on the TV.
2.While holding down the RESET button on the
remote control, press the POWER button on the TV front panel.
The TV will turn itself off, then back on again. Release the
RESET button
Ajin
Jan 23, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Shuts off and will not turn on
If the model listed here--wd65737 is correct you may have a bad lamp. If another brand and or model it would depend on more information.
Apr 22, 2012 | Mitsubishi WD65737 65" DLP TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,048 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
