Dishwashers Logo
Netball Tours Posted on Mar 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher floods instead of filling The water comes into the system but the flat plastic deposit on the side just fills with water and then floods, and no water goes into the dirty plate compartment (the interior of the machine)
Jim DuBreck
Level 3:
  • Master 578 Answers
  • Posted on Mar 11, 2014
Jim DuBreck
Master
Level 3:
Answers
578
Questions
Helped
252760
Points
1695
Possibly food blockage. You can try shooting some air under pressure into the fill hole to blow it free. A simple shop vac on "blow" may be enough if you do not have a small compressor. Other possibility is the exhaust going into the garbage disposal is blocked so that the water cannot exhaust and any amount added floods the unit. (first item is most likely).
Jim
5 Related Answers
pwinyard
  • 3 Answers
  • Posted on Oct 22, 2008
SOURCE: Dishwasher fan fills with water
Well, I just took my hose out (pulled both ends off the connectors) and it was indeed full of junky cruddy muck, so blew it out over a waste bin until it ran clear through. Now I've put the hose back on and will see what happens next wash!
Anonymous
  • Posted on Jan 17, 2008
SOURCE: Indesit dishwasher sump keeps filling up with water when turned on
I had a similar problem every time i bailed the sump out by hand and turned the machine back on it would fill the sump or just shut off.
Having spent ages checking various site it boiled down to one of three things there is a thermostat switch underneath they are know to go on the indesits and cost next to nothing to replace
second cause and most probable is to take machine outside before you do this front cover below front door removes to give access to pump you ll know it the pump because it has a pipe rinning into it and one out on my indesit i turned it upside down and got really easy access to it comes of easily take it to pices bit by bit really easy probably need small allun key depends on model check put for foreign objects , spinx blackpool rock etec etc only kidding it might be a bit of plastic or something that stop the spindle turning freely inside the pump if you find anything clean put back and off you go if pump is knackered you can get them off the web for 4.95
last but not least is the problem that mine actually had in the end and the easiest to fix `water pressure` if there is insufficient water pressure the machine regognised this and activate a shut off valve the machine lights flash you can reset the programme but it still does nt work. take the water pipe off the back put it into a bucket and open the valve you ll now what good pressure looks like mine was poor when i took the adjacent kitchen unit out it transpired a shut off vavle had been placed on the pipework the vavle had never been opened fully by the plumber and was restricting the water supply . take your time dont rush and be methodical take advantage of a local parts supplier ash them what most repairers will do first. it can be very rewarding to find that a/ you can do it and b/youve saved 60 or 70 quid in the process.
ps never mess with the machine whilst connected to the mains or spiky hair might come free with the repair and do take the machine outside or you ll have water evrywhere trust me
Anonymous
  • 878 Answers
  • Posted on Jun 17, 2007
SOURCE: dishwasher filling correctly?
john, the dishwasher has a timed fill, make sure you are using 3/8 inch line. If you are using 1/4 inch, that would be your problem. The fill should be just below the heating element. If you are using the 3/8 inch line, the next suspect would be the fill valve itself. Make sure nothing is kinked, Catriver.
Anonymous
  • 734 Answers
  • Posted on Dec 02, 2008
SOURCE: Kenmore Dishwasher 665.1671590 Leaking water at fill funnel.
Step1
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Step
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Step
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Step
5
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Anonymous
  • 56 Answers
  • Posted on Jan 05, 2009
SOURCE: BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Why doesn't my dishwasher spray?
Wash motor may be faulty or the wash arms are clogged.
But if it simply fills and drains continuously then the flood switch has triggered. There could be water leakage which floods the base. Turn the dishwasher off form mains power. Pull out and tilt to one side to get water out. Then after a wait of few hours to allow things to dry, reconnect and see.
5answers
Dishwasher will not fill with water
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Jun 18, 2008 • Dishwashers
2answers
Hi, i've taken the top and sides off my Bosch dish washer sgs45e02gbas it has not been working. the problem is ....when you switch it on is there is a pumping/throbing noise but doesn't continue...
Hello Phillip,
The reason only the pump runs anytime its powered up is because the flood detector has detected water in the base of the dishwasher and until that water is gone only the pump will run.That flood detector is (when looking at it from the front) is in the left front corner,its a styrofoam disc with a rod in the center of it and has floated up activating the flood switch on the letf side wall where the water enters the tub (can be seen on the left side with side panel removed) if thier is no water in the base frame perhaps some foreign object has wedged itself under the sytrofoam disc holding it up. Until the water is out of the base frame only the pump will run as long as the flood switch is tripped.
Possible things that will make water be in the base frame are,
oversuds from too much detergent
a leak of any component or hose
a defective water level switch allowing it to overfill
GENE
No water coming into dishwasher
dishwasher will not fill with water: This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned. ----- There's no water entering the machine If there's no water entering your dishwasher, check these: Water-inlet valve Float switch Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it. Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Bosch dishwasher = machine on but no water, so the lower basin has water in it and because of it the FLOOD CONTROL SWITCH IS ON, so how do I drain the rest of the water so the FLOOD CONTROL SWITCH goes...
If you can see the water use a shop vac if not you will have to pull the unit out and remove the left side panel after removeing the water you will need to find the leak that caused the bottom to fill with water
11helpful
Code i30 has been activated - can i solve it my self?
on several of models the water reservoir , the plastic house on the left side must be cleaned, and the big hose in the bottom from reservoir to the center is filled with fat so the water fills to slowly and it runs over in the reservoir overflow hole and down in the bottom. this , little by little fills up the aqua stop sensor system. This causes water in the bottom of your machine and water block system to trig..No not on hose but a float in the base of machine. Tilt washer on side to drain water out of base allow to dry and should cure the fault 30 prob.
remember to disconnect from the mains electricity before doing this..also clean out any hoses connected to this...as the fats accumulate it clogs the lines and water slowly starts to fill in the bottom which activates the float and thereby triggering the fault .30code..this should save you a call out charge
.Hope this helps...please rate me...the Fang
3helpful
My bosch dishwasher does not fill with water (although it drains)
most bosch have the inlet valve at the end of the fill pipe and it has an anti-flood device.
try turning off the water, take off the fill pipe then reconnect it and see if this works.
taking off the fill pipe resets the anti-flood device
1helpful
Not emptying or filling
3helpful
Bosch dishwasher SHU66C02UC
You have water in the base of the machine. There is a flood float in the bottom so if any water gets into the base, it will shut off the water and run the drain pump as long as the power button is on. So shut off the breaker, remove the toe kick, and remove any water that is down there. Now start the machine and see if water is leaking into the base. If there isn't any water, an the dw is still running the drain pump, then with a wooden spoon raise the red plastice stick on the left side of the dishwasher up and down. It is possible that the overfil float is stuck. If this makes the dw start filling, then run cooking oil thru the dishwasher on the scrub cycle to remove excessive detergent. If you are in hard water, then the water deposits have caused this. Run citric acid ( Tang orange drink, Dishwasher Magic, or such) thru the dishwasher to remove this.
Whirlpool built in dishwasher. not aware of model number
Putting vinegar in the bottom of the dishwasher is not going to help because it has nothing to do with the FILL cycle. The bottom (or sump) actually is used during the WASH and DRAIN cycles. I would check the fill port where the water inlet hose goes into the side of the wash tub. You will need to pull the unit out and locate the inlet hose on the SIDE of the dishwasher. The hose should be a black rubber hose located on the left-hand side of the machine. I had a very similar problem that turned out to be calcium deposits clogging the fill port BEFORE it got to the fill valve. With the unit turned off, I removed the rubber hose and used a small screwdriver to poke straight down into the fill port and break up a bunch of calcium. The unit worked fine after that. It is normal for some dishwasher models to drain if they do not detect enough fill water, or if they detect a leak. Usually when the fill port becomes restricted or clogged you will find puddles of water forming under the dishwasher. You might want to remove the bottom panel and check for leaks as well (if you haven't done so already). If you check the fill port and it is clear, the fill valve could be a possibility as well. However, you mentioned you could hear water running which leads me to believe that you have a simple clog somewhere...but, the valve could have accumulated some deposits as well. Check the fill hose and let me know. Good luck and I hope this helps you. PS Another common mistake people make is to put drain cleaner in their dishwashers. This can damage the pump and chopper assembly. Not to mention, it could be harsh on the some of the rubber seals. Not a good idea.
Top AEG Dishwashers Experts
Paul Carew
Dominic Harborne
Level 1 Expert
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
