Question about Haier HDP18PA Stainless Steel Free-Standing Dishwasher
Why Does Fault Alarm Beep at End of Cycle?
The dishwasher washes everything properly, which is good. But I cannot figure out why the buzzer comes on at the end of the entire wash. When I plug it in to start it, the power button and other set lights come on. But I still must press the power and start buttons to begin the washing process. After it's complete, it beeps the usual amount of times and then the loud buzzer (fault alarm) sounds until I pull out the plug. I am wondering why the door panel lights up when I plug it in and why the alarm beeps when the entire cycle is complete? Please help. Thanks.
Posted by Sherilyn Re on
Perry
    Sergeant:
  • 223 Answers
Check any user friendly ports, filters, screens. It appears that the washer is trying to tell you something. See your manual for troubleshooting. BLEEP BLOOP
Posted on Mar 10, 2014
2 Related Answers
Anonymous
SOURCE: I have a Haier quiet clean unsure of model number
buy a new one!!! lol
Posted on Sep 08, 2009
Anonymous
SOURCE: Our Haier HDC1804TW counter-top dishwasher
Since mine does the very same thing, it's my guess that is the sterilising cycle as by this point it has already washed, done a short fill to remove any remaining detergent, and two rinses. I'm also assuming the second short fill is just to cover the heating element and/or to to generate an amount of steam having being heated by the element (I'm basing that assumption on the heat of the dishes at the end of end of the cycle and the heat of the water when it drains)
Posted on Apr 04, 2011
Where is the distributary valve?
that is a very good question
i cant find a "distributary valve" for sale
lots of water inlet valves hot and cold single units
almost every dishwasher user manual and has code e8 mentioned and faulty distributary valve
why the fault
.If the distributary valve have worked for 150
seconds, and could not reach right
position during wash cycle,after the cycle is finished, the dishwasher will shut off all
loads, the alarm buzzer will ring for 30 seconds and the window will display "E8" at rate
of 1Hz in 30 seconds, and then display "E8" , drain water for 2 minutes meanwhile
May 12, 2016 | Dishwashers
What is fault E3?
E3 means that the heating element is operating when it should not be doing so. It may be caused by an older, weaker element that is taking too long to heat the water or the thermostat may be giving incorrect readings. Ensure you are using hot water to fill the machine (if tied to your faucet water supply, run the water until it is hot before starting the dishwasher). Information from the Belling manual:
If the heating element is still heating after the allowed time, then the control board will advance the programme to next step and at the end of the washing cycle the alarm buzzer will sound for 30 sec and the display will show E3.
When the control board detects that the heating element is operating during a non heating step or during the internal test the heating circuit is found to be open circuit then the alarm buzzer will sound for 30 sec and the control board will cease all functions except for the drain cycle which will run for 90 seconds and then E3 will be displayed on the control panel.
Mar 06, 2016 | Belling 24 in. IDW603 Built-in Dishwasher
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
Water goes in it washes for little while then buzzer starts before wash cycle ends
Hi Gina,
When your machine stops during the cycle does it beep & hold some of the wash progress lights on?
This is how it displays where the fault is coming from.
The motor controller is the most common for this type of fault.
Thanks
Damien
Nov 07, 2015 | Fisher and Paykel Washing Machines
Miele Advanta dishwasher beeping
Buzzer
The end of a program and faults can be
announced by a buzzer tone.
The buzzer at the end of a program
sounds five times in intervals with a
brief break in between. The buzzer
sounds up to one hour if the
dishwasher is not turned off.
The buzzer for a fault sounds
continuously. The buzzer sounds for up
to two minutes if the dishwasher is not
turned off or the fault is fixed.
The buzzer is activated by default. It
can be set to off, so it does not sound
at the end of a program. The buzzer for
a fault cannot be set to off.
^ Open the door.
^ Turn the dishwasher off o.
^ Press the program button and at the
same time turn the dishwasher on g.
Hold the program button until the
lower right program indicator comes
on.
If it does not come on, start over.
^ Press the program button briefly four
times.
The "Intake/Drain" indicator flashes 4
times in intervals.
The upper right program indicator
shows if the program end buzzer is
turned on or off.
- Upper right program indicator
flashes: Buzzer is turned on
- Upper right program indicator is off:
Buzzer is turned off
it is not easy to disable the buzzer. you have to hold the buttons down exactly the way it tells you to in the manual. you also have to pay attention to the lights and make sure they are flashing the proper sequences. try it two or three times. you will eventually get the hang of it. not sure where you live, but the miele techs have a computer that allows them to disable the beeper if you are unsuccessful. the proceedure is copied below.
^ To change the setting, press the
"Intake/Drain" indicator lights.
three times.
The setting is saved.
Jun 14, 2012 | Miele Advanta G2170SCSF Dishwasher
How do you turn off the HWS alarm on a makita bmr100
A beep tone will activate when selecting the HWS buzzer
alarm.
The alarm beep will become shoter and shoter every
15 seconds for one minute followed by one minute silence
before repeating the cycle.
The HWS alarm will sound for one hour until turning off by
pressing the Power button. Press the Power button whilst
the alarm is activated will cancel the alarm for 24 hours.
1. The HWS buzzer alarm can be set either radio is on or
off.
2. Press and release the HWS buzzer alarm button
, the symbol will flash.
3. During the symbol flashes, long pressing the
button for more than 2 seconds followed by a beep
and display Hour digit will flash.
4. Rotate Tuning Control to select required alarm hour,
then press time set button again. The minute
digit will then flash.
5. Rotate Tuning Control to select required alarm minute,
the press time set button again to complete HWS
buzzer alarm setting.
6. Press and hold down buzzer alarm button for
more than 2 seconds followed by a beep to switch on
or off the HWS buzzer alarm.
Display will appear when buzzer alarm has
been set.
May 25, 2011 | Car Audio & Video
Our Haier HDC1804TW counter-top dishwasher does not complete the washing cycle. It stops after 90 minutes which should be 115 minutes for heavy washing according to the manual. The washing light is...
Mar 05, 2011 | Haier HDC1804TW Dishwasher
END OF CYCLE ALARM
The manual on my Bosch 500 plus 4.2 says to select a cycle and then push and hold two option buttons until you hear the beep to turn off the audible end of cycle alarm. Hope this works for you! P.S. It says not to try this with a load of laundry in the machine.
Jan 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Stops mid cycle
It may be a out of balance alarm during a spin cycle. Re-balance the clothes and hit start.
Jun 12, 2008 | Fisher Paykel EcoSmart GWL15
Haier HDP18PA Stainless Steel Free-Standing Dishwasher Logo
201 people viewed this question
Top Haier Dishwashers Experts
Marvin
Marvin
Peter
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
