Question about Logitech MX1000 Laser Cordless (097855023933) Mouse
Where to find charger cable for MX1000
Where can i find a charger cable for the logitech mouse MX1000 i really need it
5 Suggested Answers
Anonymous
SOURCE: Logitech wireless mouse
The battery is under the top side of the mouse; use the tip of your fingernail to lift it up, pop it off gently; then you will see the battery inside.
Posted on Nov 02, 2007
Anonymous
SOURCE: Logitech mx1000 Not charging.
I had the same problem with the mouse MX1000 not charging when it is on its charger.
Then, I realized that I forgot to plug the adapter for the charger - this charger is not taking its power from the USB port but from an external charger!
Once I plugged the charger, the mouse recharged without any problem.
I hope this helps.
This mouse is really great, once this question of recharge is solved.
Stephan
Posted on Mar 24, 2008
Anonymous
  • 270 Answers
SOURCE: MX1000 Laser Cordless Mouse, setpoint doesn't seem to work
install mouseware in the cd ,that given when you buying
Posted on Jan 12, 2009
benwabnick
Ben Wabnick
  • 2404 Answers
SOURCE: docking station for MX1000 Laser mouse not working
That docking station has a lithium-ion battery in it that supposedly never needs replacing. I'm wondering if the battery did go out on it and needs to be replaced. If there is now way to get inside of the docking station then you will need to get another mouse, cause you can't just get the docking station.
Posted on May 27, 2010
Scott Smith
  • 216 Answers
SOURCE: Have logitech mx1000 mouse and
Usually the default passkey is 0000, 1234, 9876, or 1111. Try these combinations, also try leaving it blank.
Posted on Jun 15, 2011
Recharger doesn't recharge
mcdevito75 here, The batteries in the mouse could be going bad, old.
Jun 29, 2010 | Logitech MX1000 Laser Cordless...
Docking station for MX1000 Laser mouse not working
May 27, 2010 | Logitech MX1000 Laser Cordless...
I cant open the mouse to get to the battery.
Hi
Please see the link it has a excellent guide
http://www.vk2k.com/Logitech-MX1000-Battery/
Please can i ask that you leave feedback and vote if this has been useful
Feb 10, 2010 | Logitech MX1000 Laser Cordless...
How to replace batteries on logitech cordless mouse??
see http://www.vk2k.com/Logitech-MX1000-Battery/
HTH
Dec 08, 2009 | Logitech MX1000 Laser Cordless...
Looking for a charger for this mouse
go to radio shach anget sku #273-0029 3-12 vdc seletable power adaptor/charger with tip "g" use the positive tip configuration ,(this will make sense later).
Plug into cradle ,there ya go.
cost 19.99 +tax
mine works nice and if you have another charger go oit that is 3,4.5,6,7.5,9,or 12 then all you need in a bind is another adaptor plug to match.
Mar 22, 2009 | Logitech MX1000 Laser Cordless...
Charger no longer charges
Clean the Contacts with an eraser, fine steel wool or light sand paper.
Feb 18, 2008 | Logitech MX1000 Laser Cordless...
Laser Mouse MX 1000 By logitech
Pretty much I cannibalized a pack of battery charging adapter plates, soldered the three wires to them, trimmed & bent them a little.. and then epoxied them down to the battery hold-down in their appropriate places. A little trimming was done on the plastic so the contacts could reach in far enough without obstruction.
After having the mouse sit around useless without a working battery in it.. for months, which definitely irritated me... I looked up 3.7V li-ion batteries and came across the "klic-5001 battery" (google it) and ordered two. The first one I destroyed trying to solder the wires directly to the battery contacts.. which just ruined all the internal li-ion battery components(i.e. DO NOT TRY DOING THAT)... the second battery, which I never tampered with whatsoever, is connected to the mouse via the contacts I described above. The klic-5001 batteries by the way do fit very well in the hold-down meant for the original battery.
End result: one, exceptionally well working MX1000 mouse which I can replace the rechargeable battery inside anytime it begins to get to aged and not working so well... ^_^ It charges as normal and the battery monitoring works like nothing ever changed.
Nov 04, 2007 | Logitech MX1000 Laser Cordless...
I hope this helps.
Stephan
Oct 27, 2007 | Logitech MX1000 Laser Cordless...
Logitech MX1000 Laser Cordless (097855023933) Mouse Logo
Top Logitech Computers & Internet Experts
Ekse
Marvin
Marvin
Thomas F. Schneider
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
