Have 2 Docking Stations - lost power day- on won't play?
Lost power in house for 2 days. When power came back, possibly had power surge. Could Docking Stations have been damaged by surge? If so, what is the fix?
If you did not have it connected to a surge suppressor it is smoke the power supply board. And as much as I hate to say it Emerson does not usereplaceable components it will be cheaper to buy a new set sorry dude.
It will be drivers. I had endless problems with a toshiba dynadock which took days trying to sort out. Once Toshiba released the windows 8.1 driver it worked a treat. You will need to use different drivers for each docking station.
Make sure that all the plugs are plugged in. Try a different outlet, if it's plugged into a surge protector make sure that it didn't trip. Or if is plugged into a regular power strip press the reset button on the side of the strip. If that doesn't work there usually is a fuse inside the PC that might have blown.
I hate to be the bearer of bad news, but there is no reset on the phone system, and it's a near certainty that a power surge during the storm "fried" the sensitive circuitry in your phone. The same thing happened to me a couple of years ago and I ended up replacing my phone system. A corded phone in the house at the same time lost its ringer during our storm. To this day it still works fine, but will not ring. While you cannot save your present equipment, it's possible to protect your replacement by installing a phone line surge protector (available at just about any store that sells phones or computers) and a whole house surge protector that you install at the main outside breaker box (you'll need to search the web for that one. Look for a SYCOM surge protector).
wat temp are you runninr in the refrigerator side? it should be at 38 degrees because now days the are using an averaging sensor inside and also if tis any colder yoou will possibly freeze you produce
Try updating the drivers for the docking stations. Even in commonly used items such as docking stations which can be used without drivers, if you go to the manufacturer's web site and download drivers or management software, you will find it works better.
Otherwise, try somone else's laptop with those docking stations to make sure it's not your latop causing the problem. If it doesn't work for them either, the docking station is broken and there is really nothing you can do about that short of paying more than it's worth for someone to change out the USB component of the docking station.
If the battery outlets do not work, typically the Dynex TE685AVR UPS (battery backup) just needs a new battery. These batteries usually last 3-5 years.
