HP Photosmart 8150 InkJet Printer Logo
Posted on Jun 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My HP Photosmart 8150 has started printing color
My HP Photosmart 8150 has recentlystarted printing color images way too dark even when the image that is displayed on my monitor is well balanced. I am using recommended HP cartridges. How do I correct that.
malcrat
Level 2:
  • Expert 68 Answers
  • Posted on Jun 13, 2009
malcrat
Expert
Level 2:
Answers
68
Questions
0
Helped
18721
Points
136
You may have a colour management problem. Your monitor may need to be recalibrated from the software you are using to print your images. Your printer too may need to be sorted by calibaration too.
On an HP Photosmart 8150 printer, Do I set my Driver Installed Print Cartridge to Tri-Color, Gray Photo to use only the black ink and avoid using the colored cartridge?
That is entirely up to your personal preferences. I sue black foa almost all except things like coupons and other documents that the color is needed to make it useable.
How do I set to mirror image print
Here is the manual for the printer: http://h10032.www1.hp.com/ctg/Manual/c00230474.pdf , but there is not a reference for mirror image printing. Check your application software for capability to mirror print.
I can not print in color off internet at all
There are advanced options in your browser to specify Use My Colors versus Default.
Also uncheck Print Background images
How can i get my HP 8150 to print in color? I think this is a problem with my laptop (Compaq) because i have two printers and they both will not print in color from this computer. Please help
Open a document or type something into wordpad,then go up to file,then print.Select the 8150 and go to properties.Somewhere in there,you'll see an option to print B&W or color.Make sure it isn't set to B&W.Should work with your other printer too.
Bob
2answers
The photos are coming our dark
Hi
Check the Following link for Enhance Image
HP ENHANCE Image
  1. From the application you are printing from, click Print , and then Properties . The Print Properties screen opens.
  2. Click the Paper/Quality tab.
  3. Select dpi (light to dark )
  4. Click OK .
Have a HP4180 deskjet printer that also scans. How to get images in the computrer?
The user manual that came with the printer should explain how to do this.
See extract below
Scan an image
You can start a scan from your computer or from the HP All-in-One. This section
explains how to scan from the control panel of the HP All-in-One only.
To use the scan features, the HP All-in-One and computer must be connected and
turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software
(Mac) must also be installed and running on your computer prior to scanning.
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the
Windows system tray (at the lower right side of the screen, near the time) to verify
the software is running.
Note Closing the HP Digital Imaging Monitor icon in the Windows
system tray can cause the HP All-in-One to lose some of its scan
functionality. If this happens, you can restore full functionality by restarting
your computer or by starting the HP Photosmart Software.
● On a Mac, the software is always running.
Tip You can use the HP Photosmart Software (Windows) or HP Photosmart
Mac Software (Mac) to scan images, including panorama images. Using this
software, you can also edit, print, and even share your scanned images. For
more information, see the onscreen Help that came with the HP All-in-One.
To scan to a computer
1. Load your original print side down in the right front corner of the glass.
2. Press Start Scan.
3. Press OK to select the default application to receive the scan, or press to
select a different application, and then press OK.
A preview image of the scan appears on your computer, where you can edit it.
4. Make any edits to the preview image, and then click Accept when you are
finished.
HP Photosmart 4150-I am unable to get the colored ink on a print from a website. My ink is new, color and black. Thx
if colored printing fine from other application ( Word, excel etc) then pls follow theses steps -------- in internet explorer goto tool ----- advance ------- look for Printing in the list and check the box Print background and color and images.
I have a Hp Photosmart 8150 Printer and Lost the CD
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=397810&
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Printer stopped printing color images
hi im josh in cebu phils .friend may i help you? The problem appears on your print out is a symptoms of software corruption. Try to re install new software driver for printer. but dont forger to uninstall the old one before installing a new. check also the printer port connection. good luck hope i helped you.
k24674
Grand Canyon Tech
Grand Canyon Tech
