SOURCE: leaking whirlpool washing machine
The exact same thing happened to me several months ago, had to replace the pump motor, works fine now. Hope this helps!
SOURCE: Suds and F35 keep shuting down my laundry day:(
Remove the service panel and see if the filter has something in it
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My Whirlpool Auto Load Sensing
Hi
To reset the Whirlpool washer turn off and unplug it, restart the washer after 30-40 minutes and check if the washer is reset. Let me know if you get any error code after restarting the washer. If no error code appears then the issue can be due to faulty door switch, remove the top cover of the washer and check the connections to the door switch. Hope this helps... Please post back with complete model# if you need more information.
Daniel
